Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: K5-52-3s
Old 07-08-2007, 04:27 PM   #1
Default K5-52-3s
Heres the start of my build. Right now I am learning how to set up and remedy problems. It is all together but is just a mock up. I am going to redo the links and it will have 11"wb, 4"belly clearance. I will probably eventually get all ts for it. It will just be a basher. onto the pics.
/\ here you can see that it is anatomically correct.
Then link and shock mounts.
the way the shocks were mounted but they moved to much and the axles could pivot.
The new setup and the shock tower. I am using maxx shocks not sure on the spring set up as of yet though.
Those were with the loose and full droop shock setup. Nearly 90* It is going to be alot less.
cembom is offline   Reply With Quote
Old 07-08-2007, 05:21 PM   #2
USATorque55's Avatar
Your link setup is the reason why your axles are moving side to side, there is zero triangulation.
I suggest you contact Kaetwo or find someone who has the K2-3S/L build document to look at how you mount your links.
USATorque55 is offline   Reply With Quote
Old 07-08-2007, 07:10 PM   #3
I lost my vendor privileges
it does look good. and the links need to look like this
lVl
clodstall is offline   Reply With Quote
Old 07-08-2007, 07:15 PM   #4
Originally Posted by M715ForLife View Post
IMHO, this should be in the TLT rig section, not the 2.2 scalers.
Other than that, it looks good!
Thanks man. It is going to run a full body and the flex is going to be limited alot. and it will be more of a basher. I think I might use a maxx titan in it so not really a crawler.
lVl
Thanks torqe and clodstall. Thats why I posted, I want sure. So the uppers should come together at the axle or at the chassis?
I should have it running tommorow. Tonight I am going to redo the links and finish the shocks. Then I will go to the hobby shop and get more bolts so that they all match lol. I also need to figure out body mounts. Thanks again guys.
Old 07-08-2007, 07:18 PM   #5
these might help also
http://www.reignrc.com/accessories.html
Kranberry is offline   Reply With Quote
Old 07-08-2007, 07:28 PM   #6
I was thinking that I didnt need any with this chassis lol. I might have something I can peice together at home so I dont have to order anything yet. Thanks alot fella's.
Old 07-08-2007, 10:09 PM   #7
Got the shock mounts/towers on. It almost remedied the axle movement completely. I just got the build document and I think I am going to set it up like that. I might not though because the problem seems fixed and it doesnt seem triangulated in the build docu.
Here are a couple new pics.
Old 07-08-2007, 10:16 PM   #8
'08 2.2 National Champ
Just Zach's Avatar
You don't need to run a lot of triangulation on a k2 build. I have 3 of them, all different length links/wheelbase and have never had problems with a lack of triangulation
Just Zach is offline   Reply With Quote
Old 07-08-2007, 11:09 PM   #9
Why do you think it should be in the TLT section? Because the ride height is so high and the links aren't even close to being parallel with the ground?
I am asking, because I have the same chassis, I am doing several things that are pretty unusual with it and hope I don't get the same response when I post it for the first time, i.e. a suggestion to move it elsewhere.
Bacon is offline   Reply With Quote
Old 07-09-2007, 12:29 AM   #10
There isn't too much in the recommended setup, but just the little amount stops any axle sway, even without shocks.
Torque
Old 07-09-2007, 07:25 PM   #11
Okay got the trans mounted but got a couple problems. Does anyone know of a grub screw that will work with the maxx shafts and the stock tlt axle input?
Also I think I may have a problem with driveline angles. Can anyone give me some advice and pics and info. Oh yeah by the way I am using a magnum and maxx shafts. Pics soon.
Old 07-09-2007, 08:22 PM   #12
Some updated pics, now with tranny and body mounts but thats about it.
After I figure out the shafts it should be running. Then it will be tuning and upgrading.
Old 07-09-2007, 08:26 PM   #13
Oh yeah one more thing for I am off. No one makes any input shafts for the tlt axles that have pre drilled holes through them do they? I think they would be sweet. I think the main problem is that. It only binds when the shaft plays and comes part way off at an angle. If not I think I will get these.
Old 07-10-2007, 12:19 PM   #14
No one? Well I drove it 2wd and no shock springs and was suprised. I even tried going down the stairs. Went down the ledge to the back door easy. Went down the first stair at an angle did it first time. Second and third too easy. Then on the fourth the battery fell out and pulled the truck end over end. Was not pretty. It was fine though lol.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/2-2-scale-rigs/77254-k5-52-3s.html
Posted By For Type Date
Proline Chevy Blazer body - RCCrawler.com Bulletin Board This thread Refback 10-04-2011 04:02 PM
