| | #1 |
| Rock Crawler Join Date: Jun 2007 Location: Hopewell
| I am setting up a 2.2 with WK axles, jpcustoms shocks, custom delrin chassis and links with a 12.25" wb on a 60/40 setup. I will be running the R2v2 with an axiom 55T motor and EVX (for now, MOPED soon) ESC. My question is for those of you running a 2.2 with R2 and 55T motor, what pinion are you running and are getting the best performance from? I plan on trying an 8 tooth and 13 tooth but if someone recommends something from personal experience I'd like to know your results. I searched for quite a while and only found that 8-13 can be used. I also found the complete R2 gearing list but was hoping to hear from you all with real experiences. Thanks. |
| Sponsored Links | |
| | #2 |
| I had the hottest girlfriend at the MSD Nats Join Date: Dec 2006 Location: Hecho en Tejas
| ive used a 21t in my r2, thats a whole nother story. but you would probably go for a 12. thats what i would choose for myself. |
| | #3 |
| Rock Crawler ![]() Join Date: Jul 2005 Location: Phoenixville
| I had an R2 in my 2.2 with WK axles and ran a 13tooth, wheels speed still seemed a little to slow. i was acctually gonna try a 15 tooth. |
| | #4 |
| Quarry Creeper Join Date: Jan 2007 Location: 2 miles from nowhere MO.
| I run a 12 tooth pinion with mine. I have an axiom 65 turn with a novak super rooster esc. But I run a 3 cell 2480 mah Lipo at 11.2 volts and I have more than enuf wheel speed in my comp rig |
| | #5 |
| RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
| | #6 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| I would suggest the 8t pinion on 9-12 cells. |
| | #7 |
| Quarry Creeper Join Date: Feb 2005 Location: Vancouver Island B.C.
| 12t on 8 cells was pretty good, but a little slow for a trail type rig IMO. |
| | #8 |
| | #9 |
| I use the mamba max in about everything. |
| | #10 |
| Nor-CalRCRC ![]() Join Date: Dec 2006 Location: Monterey Peninsula
| I run a 16t with 8cells and a 55t. Great wheel speed and good low end. I might go to 15t though because I don't really need quite so much wheel speed. I have one of the original R2's and had to grind the opening to get the 16t in there. I don't know if the newer ones are the same. |
| | #11 |
| RCC Addict Join Date: Mar 2007 Location: MS Gulf Coast
| I am currently running the 8T but it is rather slow, but it can crawl up a freakin wall! |
| Thread Tools | |
| Display Modes | |
