Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: S-10 Hardbody Build
Old 08-20-2007, 11:52 AM   #1
avengernut's Avatar
Default S-10 Hardbody Build
I've been working on this a little bit and I figured I would post a picture of it.I have two 4x4 S-10s that I drive so naturaly I had to build a scale one.The body is from a Radio Shack Eradicator and I also have one that is trimmed quite a bit, also from a Radio Shack truck called the Aftershock.
Aluminum frame made by me(11"wb)
Pede trans
Tlt axles
645 servo
Geo's
Rc4wd beadlocksClick the image to open in full size.
avengernut is offline   Reply With Quote
Old 08-20-2007, 12:24 PM   #2
Default s-10
I like the chassis,nice and plain. i cant get enough of the solid axle builds,i will be watching this one!
WOODS is offline   Reply With Quote
Old 08-20-2007, 12:37 PM   #3
avengernut's Avatar
Thanks.I know S-10's don't have a solid front axle,but some of the 1/1's are converted to them.
Old 08-21-2007, 12:00 AM   #4
dirk379's Avatar
Heck yeah i love s10's.
dirk379 is offline   Reply With Quote
Old 08-21-2007, 05:03 AM   #5
i got a 2000 blazer i would like to do a scale version of but,i got a bruiser i just started to redo. dont want to get too many project going at once!
Old 08-21-2007, 10:52 AM   #6
avengernut's Avatar
Default S-10 Build
Here's a pic of the frame with the cross members and axles mounted.The frame is made out of 3/16 alum.I got it at a place that makes coal truck dump beds.When they trim pieces off of a part they are making they put them in a big dumpster.What a gold mine!Very cheap too.Three bucks for a long straight piece.Another good source for thin alum are sign shops.They usually have a white coating on their alum so it makes it easier to draw on.Thats where I got the material for my clod chassis.Click the image to open in full size.
Old 08-21-2007, 12:36 PM   #7
Looking good so far.
Headshok88 is offline   Reply With Quote
Old 08-21-2007, 07:47 PM   #8
yes i own a 2000 extreme s10 nice looking build keep us posted
JTrusley77 is offline   Reply With Quote
Old 08-22-2007, 01:27 PM   #9
looking good!
aircruiser is offline   Reply With Quote
Old 08-23-2007, 10:44 AM   #10
avengernut's Avatar
Thanks for all the good comments guys.Got the rear knuckles locked out this morning.Still need to do the lift bars and mount the shocks and then the rear will be done.
Old 08-23-2007, 10:57 AM   #11
post some pics of the rear when you got it done. i have a bruiser that was four linked when i got it,but i cant seem to get the right movement out of it!
Old 08-24-2007, 12:50 AM   #12
avengernut's Avatar
Default s-10 build
Wish I could afford oneDo you have a pic of your rear setup?Maybe I could help you with it.
Old 08-24-2007, 12:53 AM   #13
Trucks lookin good man should be one of the few scale S-10s out there if there even are any.
aggressivellc is offline   Reply With Quote
Old 08-24-2007, 06:15 AM   #14
yes i will post some pics this weekend,any help would be appriciated
Old 08-24-2007, 09:51 PM   #15
L-TOWN CUSTOMS's Avatar
any updates on this ?
L-TOWN CUSTOMS is offline   Reply With Quote
Old 08-24-2007, 10:11 PM   #16
slugzracing's Avatar
As much as I despise the S-dimes I like to see something different
When do we get a body on chassis mock up shot?
slugzracing is offline   Reply With Quote
Old 08-25-2007, 09:35 AM   #17
avengernut's Avatar
Unhappy S-10 Build
Here's a mockup pic of the body.Still have to lose the chrome headlights and blackout the grill,trim the flares and the front and back bumper.Anyone know anything that will remove decal glue without harming the body?Don't use a heat gun and try scraping it off!I put a small crack in the top trying that.Click the image to open in full size.
Old 08-25-2007, 09:40 AM   #18
There is this stuff called goo be gone or somthing like that and it works very well at taking that residue off the bodies.
Mikekx65 is offline   Reply With Quote
Old 08-25-2007, 10:59 AM   #19
WD40 works great on glue just make sure it doesn't react with the plastic. I have used it on lexan, If you work fast it shouldn't be a problem. I would try a little on the inside just to make sure.
Crazy Climber is offline   Reply With Quote
Old 08-25-2007, 12:28 PM   #20
avengernut's Avatar
Default S-10
Okay'I have some stuff called PB penetrator and I tried it.No more glue.Now I just have to get that off the body
