02-01-2008, 08:43 PM | #41 |
Pebble Pounder Join Date: Sep 2006 Location: everson
i wanna see that thing at states again. it was great running "fallow the leader" with joe. I wanna wheel whit him again. (maybe barbie will be there next year) |
02-03-2008, 06:49 PM | #42 |
Quarry Creeper Join Date: Feb 2006 Location: Surrey B.C Canada
| Awsome............
02-06-2008, 08:14 PM | #43 |
Newbie Join Date: Jun 2007 Location: Berkley
i love it i must have one
02-16-2008, 11:47 PM | #44 |
Quarry Creeper Join Date: Jun 2004 Location: 462-Da Fock
My hats off to this project. Imo you took it to the next level "Realistic R/C Rock crawling". New Tubs $5.99 lol! Good Job man. |
02-17-2008, 07:59 AM | #45 |
| Every time I see this feel kinda sad it looked so nice in fresh paint |
02-25-2008, 09:05 PM | #46 | |||
RCC Addict Join Date: Aug 2005 Location: New Oxford PA
WOW I guess I need to check this more often. I didn't realize there were so many responses! Quote:
Thanks! that really means something coming from you! you're FJ is truly awe inspiring! Quote:
Just wait, I'm building another body but this one will probably have a little more protection | |||
03-01-2008, 02:00 AM | #47 |
Quarry Creeper Join Date: Jan 2008 Location: fair oaks nor-cal
friggin awsome i tried to make make a body like that and i couldnt get any of the crinkles out of it and yea ill try again that is crazy, all that carnage a stuff keep it up
03-01-2008, 08:56 PM | #48 |
Truthfully I don't get them all out either. I just make them less obvious by working the metal with something hard like a socket over the folds. once the paint is on it's hardly noticeable.
08-02-2008, 08:48 PM | #49 |
Well after beating on this thing for almost a year i figured it was time for a re-vamp. One of the things i did recently was to ditch the crappy wheels i had in favor of some stampede's. to make them work I needed to get some wheel wideners and scored a set in a trade. The new set-up makes it a little wider but I like how it looks Now it's pretty obvious that the poor flatty is in need of a new body so off came the old one The tranny set-up was always temporary as being under the frame made it way too low and I always got it hung up on things. I also wanted to lower the ride hight a bit so once I stripped the chassis I mocked it up with the ride hight I was shooting for. then I cut out some new lower link mounts and welded them to the frame I have tons of clearance now! for the upper links I welded a plate inside the frame and ran a bolt through it finally I wanted to make the shock set-up a bit more realistic so I bent up some shock hoops to put the shocks in a more vertical position. I'll go into the new tranny set-up later |
08-03-2008, 05:57 AM | #50 |
RCC Addict Join Date: Nov 2007 Location: Massachusetts
The re-build is coming along AWESOME so far..!!! I've ALWAYS loved this rig..!!!!! Its just Looks SO real, ( all beat up and abused) - My Hats off to you my friend..!!! Excellent work..!!!
08-03-2008, 09:01 PM | #51 |
Thanks man! I got you're PM, i'll get back to you on it in a bit. Well the next thing I have been wanting to do for some time is to move the tranny up into a more natural position under the hood but I would need a way to transfer the power to the wheels. After looking at the parts out of an old 3 speed, I realized what i was going to do. I started by grabbing the shafts I would need I'm not sure what they are for in the tranny but after a little trimming I had an input gear and an output gear Here is how they will be laid out Then I took what was left of my battery trey from my AX10, and cut it down to make side plated for the T-case with gears installed Input side from tranny back side Now to mount it into the chassis I bent up some sheet metal into a cross member, drilled and tapped it, and welded it to the chassis Here is the T-case in it's final position And here it is with the tranny in it's new spot I Still have excellent ground clearance and the DS angles are real good as well Finally here are some poser shots of the rolling chassis Next is the new body! |
08-03-2008, 09:52 PM | #52 |
Rock Crawler Join Date: Jan 2008 Location: Cotati
Great job! That T-case is awesome.
08-04-2008, 01:29 AM | #53 |
Pebble Pounder Join Date: Feb 2008 Location: .
Looks awesome |
08-04-2008, 05:52 PM | #54 |
I had the joy of watching this Jeep run 2 weeks ago. You have to be there to appreciate hearing the body getting mangled! Hopefully you'll be out for the 10th, I'm looking foward to it.
08-04-2008, 08:12 PM | #55 |
Thanks man! Sorry I won't be at the next comp. I have a family reunion that day. I'll try to make the next one but I won't know for sure until it gets closer.
08-04-2008, 08:37 PM | #56 |
Quarry Creeper Join Date: Jan 2008 Location: Edmonton, AB
that tcase is sweet it reminds me of an r2. come to think of it you could make it look like a dana 300 or an atlas tcase if you rounded the sides off
08-04-2008, 09:03 PM | #57 |
RCC Addict Join Date: Jun 2007 Location: Indian Village Pontiac
That is the craziest lowbuck build I have ever seen!! Great work!!!! We ahve a guy here that puts monster can skins on his Betty B17 body just for the sound and fun so I an truly appreciate the sound factor Very innovative build!!! |
08-05-2008, 05:36 AM | #58 |
I never intended it to be a low buck project but i suppose it is. I've always used what i had lying around so it seems natural to me. Well I don't have any progress shots of the body , I was in a hurry to get it done before the PA Jeep show a couple weeks ago, So here is the completed rig before I ran it. Yes the "Willys" is actually embossed into the metal The new body has some refinements to it. I added a little more detail like the lettering on the back. I cut the front fenders off the original truck to get a better mold of them, I added more bracing this time to help with the weak spots I had in the old body, and the radiator support is of a heavier gauge metal to help keep it from collapsing like the last one. Her is a not so clear shot of the underbelly One last thing, the skid plate to the left in the upper photo is actually the battery trey I had to put it there because the tranny now occupies the original location. The 2 cell LiPo fits perfectly and is easly removed by simply removing the 2 back screws and hinging it down. I'll get some after run shots up soon |
08-05-2008, 07:00 AM | #59 |
Rock Crawler Join Date: Jul 2007 Location: Beechview/Pittsburgh
Dang... Looking better than the original! Cant wait to see it at the states! Hope to see you there! |
08-05-2008, 07:08 AM | #60 |
Quarry Creeper Join Date: Aug 2007 Location: Lumberton
Looks freaking sweet man!!! |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/2-2-scale-rigs/82901-joes-flatty-revival.html | ||||
Зарубежные проекты 1.9 - Страница 4 | This thread | Refback | 10-05-2011 03:36 AM |
