09-26-2008, 01:47 PM | #61 |
Rock Crawler Join Date: Nov 2006 Location: Holland
Thanks. Realism,in looks and performance,is exactly what i was aiming at. And,ofcourse,Guido's suspension has been one of the big examples too. The weight/torquetwist problem has also been a concern to me. I chose Traxxas E-maxx blue springs and Tamiya TXT-1 aluminium upgrade dampers,for now. Funny you mention the rear swaybar.The lower links i use are made of shortened TXT-1 lowerlinks.(you can see them in the pics^^) I took the side with the (swaybar)hole off. But the idea of a swaybar has been running through my head since. I found several pics on the net of EB's (with modern specs) running a front/rear swaybar,especially the faster ones. I further reduced the weight of the chassis by taking out the three chassisrails-spreaders. They will be replaced by one-piece multi purpose parts out of aluminium.(not finished) |
09-30-2008, 02:04 AM | #62 |
RCC Addict Join Date: Jan 2007 Location: San Jose
really nice. how did you make those spring mounts. I am very curious how peopl make such fine/small duplicates of real stuff.
09-30-2008, 12:29 PM | #63 |
Thanks. I decide what i want.Do a little research.And make the parts.(handtools/drillpress) In this case the dimensions of the axle dictate the shape/dimensions of the parts. Shape follows function,you can't go wrong. Usually i round-off the corners to make it more pleasing to the eye. |
10-01-2008, 02:26 AM | #64 | |
10-01-2008, 05:02 AM | #65 |
The basic tools for most parts/builds. Use any drillpress you like/is suitable for your needs. Make sure it has variable rpm's and at least a 0.15/0.20 Kw motor. This is the one i have had for years now. Make sure you get yourself a big pile of (scrap) materials.(lexan,aluminum,steel,brass,copper,stain less,rubber,plastic) That's the real key to get into a nice and crafty scaler. |
10-02-2008, 01:15 AM | #66 |
thank you 4wd. nice job. i really do want to build a scaler.
10-18-2008, 05:26 PM | #67 |
A little progress. Frontslider,batterytray,RXmount,dashboardmount and chassis-stiffener. The lightest design i could come up with. |
10-19-2008, 01:15 AM | #68 |
keep posting pics for us. Thanks and nice work again |
10-19-2008, 01:24 AM | #69 |
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
damn this thing is sicker than my wife off three drinks. just not as cheap. hahahaha kik ass job man. |
10-19-2008, 12:32 PM | #70 |
10-26-2008, 07:30 PM | #71 |
It's a roller. F/r axle. Electronics and battery under the hood for easy access. Underside. |
10-28-2008, 12:44 AM | #72 |
Can you explain or show pics of how you did the coils up front. I want to do coils on my bronco scaler. Need some ideas and help! |
10-28-2008, 06:22 AM | #73 |
All your questions will be answered in post #58. Look at the pics and you will see how i did it. |
10-29-2008, 09:59 PM | #74 |
lol. thanks. i will.... times i am lazy to look |
10-31-2008, 10:55 AM | #75 | |
Are you still running the TLT axles? Maybe this will help.TXT swaybar,almost perfect fit. My Bronco is about as heavy as a stock TXT,so should work for me. | |
10-31-2008, 12:01 PM | #76 | |
Great idea on the TXT swaybar. You are prolly right about it being close to perfect for the weight. I'm going to make one that looks like a Currie AntiRock though. http://www.currieenterprises.com/CES.../antirock1.jpg | |
10-31-2008, 03:30 PM | #77 |
Thanks for the link. The Antirock swaybar video was fun to watch.One question i still had was answered in that video. |
10-31-2008, 06:35 PM | #78 |
RCC Addict Join Date: Nov 2006 Location: southaven
truck looks good one ? is this a honda accord 2nd gear for 98 and up? |
11-01-2008, 03:50 PM | #79 |
Thanks. That gear was a replacement gear for the hoisting mechanism of this bridge. The new bridge.(2001) |
11-09-2008, 05:45 PM | #80 |
First test.Two hour scaleGTG. I love this thing,still a ton of work to do but i really think it performs great already.(for a scaler) |
