| | #1 |
| I wanna be Dave Join Date: Jul 2005 Location: Cedar Rapids
| Since there was a couple questionable rigs built who do we go to. Do we ask our elected club leader or is there someone else? Thanks Cole |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Jan 2006 Location: In the basement
| I would also like to know this, I have personally been going to my club leader. Is there a more direct approach. |
| | #3 |
| Colt Python/SR9c ![]() Join Date: Feb 2004 Location: out in the shop, reloading ammo!
| The best bet is to go to your club rules rep. He should be able to answer any questions you need. If not, they have direct access to ask other committee members. This way, you go through the channels. That way it helps your rules leader to become even more familiar with the rules if something should ever come back up. |
| | #4 |
| Thank you he is handling it for me. Maybe the club reps could put that they are the reps for such and such club under there name. Just a thought, as it would help noobs figure out who to talk too. |
| | #5 | |
| RCC Addict Join Date: Jan 2006 Location: The Amish Ghetto
i like the idea... maybe we should put the rule committee members list up for people to view. | |
| | #6 |
| Actually all the info is posted on the www.USRCCA.com website |
| | #7 |
| i was thinking on the comps page... maybe a sticky |
| | #8 |
| It's a setup! ![]() ![]() ![]() Join Date: Jan 2004 Location: The Crawler State
| The USRCCA reps are listed on the USRCCA website. |
| | #9 | |
Once the 2007 rules are published, which sould be sometime in January we can answer questions about those rules. | |
| | #10 |
| ... Join Date: Sep 2005 Location: USA
| I'd like to see one rule change. If one can build a Tuber at anysize or width. One should be able to Narrow the width of a body. Just set a limit on how wide they can be. Like 4in min. |
| | #11 |
| Bodies must remain unnarrowed, we are working on a number for minimum width of a tuber. |
| | #12 |
| The narrow width should be the same as the Narrowest 1/10 body you can buy. Say the same as the VW Bug. 6in wide I think? |
| | #13 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| Tubers impart weight too, so I think the work involved and higher CG offset the advantage of the narrow width. Would this be measured at the widest point on a tuber only? |
| | #14 |
| It will be an overall width with the rest of the deminsions. You will not be allowed to just make 1 part to fit the width and then build the rest of the width at 2" narrower. |
| | #15 |
| Well yall better hurry up with the rules! Im building a dang tuber! |
| | #16 | |
| RCC Addict ![]() Join Date: Apr 2006 Location: Minneapolis
| | #17 |
| Quarry Creeper Join Date: Dec 2005 Location: Winston Salem
| what about a lexan cab with a tuber cage/flatbed instead of the bed? its not 70% of the original body...but the lexan would be replaced with brake line (which is heavier) and it would be the same width. |
| | #18 | |
but if you have a whole tube chassis with a lexan body, sounds good enough to me | |
| | #19 | |
| I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
that would be acceptable. | |
| | #20 | |
| I wanna be Dave ![]() Join Date: Oct 2005 Location: Columbia TN
| Thread Tools | |
| Display Modes | |
