Thread: It is ALIVE!!!!
Old 01-13-2008, 05:32 PM   #1
Default It is ALIVE!!!!
FINALLY!!! I had the chassis put together back in October, but work had me away from home for a couple of months. Now is up and running. I am going to run it and see what changes I want to make. I do what to change out the green for chrome or gray. Like everyone else, I don't really care for the Betty-body, and if you look closely at this one you'll see what happens when you are in a rush and put on the base coat too thick (after som trimming, this body will likely find itself on my E-Maxx).
My Gear:
Novak Rooster Crawler ESC
Integy 65 Turn Motor
Tower Hobbies TS-150 Servos (193oz)
1500mha 2/3 C cell split packs
Custom servo/battery trays
Traxxas TQ3 TX/RX
High-clearance links
Greatscott is offline   Reply With Quote
Old 01-13-2008, 05:39 PM   #2
Nice Scott, took you long enough
Once the weather stops sucking we need to go and try to break some parts together.
myke52081 is offline   Reply With Quote
Old 01-13-2008, 06:10 PM   #3
Dip your parts into some easy off oven cleaner (I used the yellow one) to remove the green coating, rinse, and polish back to a shinny finish...
Be careful with the easy off, it's hard on the skin and the green coating disolve pretty quickly, like 15-30 secondes...
yelo is offline   Reply With Quote
Old 01-13-2008, 06:18 PM   #4
Easy Off? No Kidding?!?!? Cool, thanks for the info!!!
Old 01-14-2008, 01:36 PM   #5
Yeah, Easy Off works great. I've done it on paintball stuff quite a few times, definitely the easiest way to remove annodizing.
Old 01-14-2008, 03:58 PM   #6
Works great! I just did some parts last night, chassis plates off my ax-10 came out perfect
JUSTGOINGSLOW is offline   Reply With Quote
