01-14-2008, 02:10 PM | #1 |
RCC Addict Join Date: Sep 2005 Location: Lehi
| question about the bent links
If I was to bend my links myself, that would shorten the WB. So I was thinking of getting the bent links, and I want to know, a couple questions. 1. Will I still be able to run my 3 link? (the top linkage setup on the ax10) 2. How far down will this lower the whole rig? Thanx guys! Oh also if I choose to go with the bent links, will they come with the rod ends? Thanx guys! |
01-14-2008, 02:13 PM | #2 |
Quarry Creeper Join Date: Dec 2007 Location: OP KS
I would recommend the stage 2 mod if you are going to upgrade to the bent links. They, at least they did on mine, will rub up front unless you pull them in closer to the pumkin...I have them on the rear, but the interfear with the springs. Do some reading on the stage 2 mod and see if you want to continue...good luck. Here : http://www.rccrawler.com/forum/searc...archid=1377543 Axial AX-10 Scorpion 1/10 Rock Crawler Kit Build, Chapter 2 "The Mod Build" Last edited by Flatcrawlr; 01-14-2008 at 02:16 PM. |
