01-14-2008, 05:36 PM | #1 |
Quarry Creeper Join Date: Aug 2007 Location: United States
| RCP Crawler Straight Axle
I got the straight axle adapters from RCP crawler. I Installed them, but I just wanted to be sure that when you do install them you only use the outside bearing from the axle carrier. The larger inside bearing does not fit. Does this sound right. Thanks, Josh |
01-14-2008, 05:50 PM | #2 |
RCC Addict Join Date: Oct 2005 Location: $t. Helen$, OR
That is how mine got installed Hope for both of us they work ;) mines still a roller so if its wrong I would like to know too |
01-14-2008, 05:53 PM | #3 |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
| That is correct. There was no need for the larger bearing.
01-14-2008, 06:08 PM | #4 |
Rock Stacker Join Date: Jul 2005 Location: Davison
What if you are still running the stock stub axles as the description says you can. You will need the second bearing to support the stub. :? |
01-14-2008, 06:15 PM | #5 |
Pebble Pounder Join Date: May 2006 Location: CANYON LAKE
No you do not need the outside bearing with the stock stub axles
01-14-2008, 07:36 PM | #6 | |
Quarry Creeper Join Date: Nov 2007 Location: Sacramento
I say go with RCP because the brand I got did not come with E-clips and I had to add extra bearings to take up the extra room. | |
