01-16-2008, 05:45 PM | #1 |
Quarry Creeper Join Date: Nov 2007 Location: san diego
| replacement shocks for my scorpion
i have the stock axial shocks right now . but after much punishment they leak . the tops have poped several times . time to upgrade. what is a good replacement shock. input please, also may think about droop.
01-16-2008, 05:55 PM | #2 |
Rock Crawler Join Date: Jul 2007 Location: Portland,OR
I got traxxas big bores and put the axial shafts in them and some longer rodends from a WK. It sits about as low as the stage 2 deal but is very nice at half droop w/ losi whites.
01-16-2008, 11:57 PM | #3 |
Pebble Pounder Join Date: Nov 2007 Location: Bay Area
integy msr10 shocks are working well for me just got to find the right set of springs to use for them. The stock soft are to soft and the hard are to hard.
01-17-2008, 08:39 AM | #4 |
Quarry Creeper Join Date: Nov 2007 Location: Bozeman, MT
The shocks from "jpcustomrc" are great - threaded body, two sets of springs - and they don't leak - check them out
01-17-2008, 08:46 AM | #5 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
I would go with the Big Bores there hard anodized teflon coated and smooth as butter. I have them on all my rigs they work great |
01-17-2008, 08:50 AM | #6 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
I like my stock shocks. If the tops are popping off you are filling too full and not bleeding correctly or have the upper spacer set up wrong. Mine don't even leak out of the bottom since I added a thin traxxas spacer between the 2 o-rings. |
01-17-2008, 04:58 PM | #7 |
thanks for all the responses to my question. i am doing some research on it. go slow
01-17-2008, 05:26 PM | #8 |
Pebble Pounder Join Date: Nov 2007 Location: San Diego
I just got some Hot Racing 120mm shocks from Hobby Central in Mira Mesa for about $30 for two shocks I think. Aluminum shocks. I am running them on my AX10 also with the stage two upgrades and have had no problems. They came with two sets of springs each. I like these much more then the stock axials.
01-17-2008, 05:56 PM | #9 |
Rock Stacker Join Date: Jan 2008 Location: westminster
| i would have to agree here. simply for the fact that they are a longer shock and would allow for more articulation. but i would modify the shock towers and move them up a little further allowing the chassis to sit lower to the ground.
01-17-2008, 09:10 PM | #10 |
Quarry Creeper Join Date: Dec 2007 Location: ON THE "EDGE"
who sells the big bores in sets of 4?
