01-17-2008, 12:03 AM | #1 |
Quarry Creeper Join Date: Dec 2007 Location: Monterey, CA
| Got my rig completed, looking for some insight before sunday comp.
Hey all, I got my rig up and running good, but I have a couple issues i was looking for some ideas about. I've searched the forums but there is a deluge of threads... Here's what I did: CKRC Stage 2 mods Moved the links in Moved the shock limiters to the inside Lengthened the upper links Axial Low CG battery plate Added 6oz to each of the front wheels Added 3.5oz to each of the rears Pede yokes and shafts Added 2nd tranny plate to mount electronics Hot racing alum knuckles Hot racing Narrow alum beadlocks Losi Rock claws Mamba Max 3S 1320mah LiPo Hitec 5955TG Hobbywing 5A UBEC Novak 55T Brushed motor the rig is weighing in at ~6lbs. I'm not real happy with the steering setup. It is not as efficient in one direction than the other. The other issue is the shocks. I see alot of options out there, hor racing has some 120mm threaded ones, and integy has some cool internal spring green ones. I was planning on running 1000wt oil and some firmer shocks in the rear. I went to the white soft axial spring in the front, but after adding the weight; they were way too soft. I went back to the stock ones. I'm going to my first comp on sunday up in Santa Cruz, so I was looking for any last minute insight on these 2 issues. I'm not going up with plans of domination or anything, just fun. But don't want to get eliminated in the first 20ft on each course. ;) Here are some pics of the rig. Thanks all and have a good one!! Cheers, Rob Kamikaze: I fixed the monster truck look. The body is lower now, you can sleep at night. *please note, no AX10's were harmed during the photoshoot. ;) Last edited by rdtshaw; 01-17-2008 at 01:46 AM. |
01-17-2008, 01:38 AM | #2 |
Quarry Creeper Join Date: Dec 2007 Location: At the Gates
hey, where is this comp at and how can i sign up? im 20 minutes from santa cruz
01-17-2008, 03:01 AM | #3 |
Pebble Pounder Join Date: Dec 2007 Location: Montrose
just a suggestion.... check your full flex in the front with your steering at full left and right lock i think your gonna rub your body and u do not want that at a comp also try flipping your bent links around the other way oh ..and if ya get a chance ...move your body posts to the top of your rig u will spend alot of time leaning against stuff....and when u do ...u will pop all your body clips off.... Last edited by saul; 01-17-2008 at 03:03 AM. |
01-17-2008, 03:02 AM | #4 |
Rock Crawler Join Date: Mar 2007 Location: Colorado
The steering problem could be because of the very short steering arm, and the servo arm moves upwards before it reaches full lock. I think your better off moving the steering arm to the other steering knuckle so that its much longer and you dont get such a mechanical exponential steering. But awesome rig! |
01-17-2008, 03:34 AM | #5 | |||
Thanks! Quote:
01-17-2008, 03:57 AM | #6 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Why did you bring the rear links in? I understand about the front (tire clearance) but in the rear it would just make things looser and weaker. Your bent links are on the perfectly right direction, don't change them. As others have said the side body posts hook on rock walls and ledges. Looks like great rig though. |
01-17-2008, 06:24 AM | #7 |
RCC Addict Join Date: Sep 2007 Location: WHEAT RIDGE, CO
For your longe sterring link, if you do not want to fab it Traxxas makes prefab ones (not as pretty as the stockers) that bolt right up, and are adjustable. |
01-17-2008, 06:25 AM | #8 |
Think everything has been answered.....Have fun out there.... |
01-17-2008, 07:14 AM | #9 |
Quarry Creeper Join Date: Oct 2007 Location: Boringville U.S.A.!
posted by Mnster. Why did you bring the rear links in? I understand about the front (tire clearance) but in the rear it would just make things looser and weaker. if u dont i think they will hit the lower shock retainer in a good flex.My boy's axial does and the links are still in the original place.[/quote] |
01-17-2008, 07:20 AM | #10 |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
the only other thing i can think of is you may want to turn your tires around... run em backwards... i think they have more bite that way... but it all depends on your driving surface... find a steep incline and crawl up it to where you have a little bit of wheel hop then, swap your tires around and see if it hops more or less... I have done this with many a tires and almost every set hooks up better in one direction then another. but this is per location as all surfaces respond differently... Have fun!! Love the body!
01-17-2008, 09:02 AM | #11 | |||
My only issue now is the shocks. I like the integy MSR10's but getting the right springs for them is going to be a challenge I think. They are also a bit top heavy, I didn't want to put all that weight up top. Could I mount them inverted? I've had a couple people mention that, but I've never seen a pic of that config on the forum, 'cept in scalers. Figured there was a reason. Would be great if I could with the Axial shocks, would help with the perpetual leaking. ;) I have the bigbores on my 2 emaxxes, and they work great. How do you mount them though? the caps are just drilled with no way to put in a ball. wouldn't that limit the travel a little if they have no lateral movement? Or is this a non-issue? I'll have to find some longer lower mounts. I think the bigbores are 100mm and I'd like them to be around 110mm. Thanks! Rob BTW, Thanks for all the compliments on the body! I'm not very excited about painting bodies, but I was real happy with this one. I decided to embrace the axial green. Was difficult, I'm not a "green" kinda guy. ;) Last edited by rdtshaw; 01-17-2008 at 09:11 AM. | |||
01-17-2008, 09:49 AM | #12 |
Newbie Join Date: Jan 2008 Location: MA
| I`m interested into see how this works out. I just ordered the bent links, and I`m going to move them inboard like CKRC says too.
01-17-2008, 10:10 AM | #13 | |
The Traxxas big bores use a rubber bladder so in theory (if they are assembled correctly) there isn't any air in the oil. You can run them upside down with no problem. I'm not familiar with the insides of an MSR10. Cool rig and good luck at the comp. | |
01-17-2008, 10:38 AM | #14 |
Rock Crawler Join Date: Dec 2007 Location: Ventura, Ca
But in a droop setup having the shocks inverted is a good thing. That puts the piston at the bottom of the shock where there is no air...... Or just get some of these 15mm shock bladders |
01-17-2008, 10:51 AM | #15 | |
01-17-2008, 10:57 AM | #16 |
i run the links just like ckrc and axial red springs all the way around works great
01-17-2008, 11:02 AM | #17 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Griz: I have to disagree the Axial shock, like a Losi shock, is an emulsion shock. The point is to mix up the air in the oil to change the dampening effect. The point of an emulsion shock is to have the proper amount of air and oil mixed. |
01-17-2008, 11:14 AM | #18 |
I wanna be Dave Join Date: Sep 2005 Location: R.I.P. Chip
In a slow moving crawler I don't think the oil/air would stay "mixed up" and would seperate easy. Just an opinion. With the Maxx Big bores running upside down insert a small section of nitro fuel tubing where the ball would be run your screw through and use a locknut and don't cinch it down real tight.
01-17-2008, 11:32 AM | #19 | |
I have built several emulsion shocks (Axial and HPI) and whenever I turn them upside down and work the shock near the beginning of compression (squeezing it 1/4" or so) I can notice the air bubbles passing through the piston. This makes the first bit of travel very mushy. I'm not saying it won't work, I'm just saying that from my experience the shocks work smoother with the cap at the top. Last edited by Grizzly4x4; 01-17-2008 at 11:36 AM. | |
01-17-2008, 11:46 AM | #20 | |
I do this also on my Stadium Truck right before setting it down to race...rapidly move the shocks and get them started, makes the truck feel better in the first few laps and basically consistent from first lap to last of the main or qualifier. They stay mixed, ever open an emulsion shock after cycling it and waiting for the bubbles to come out of the oil...might be a few hours. | |
