06-09-2008, 09:10 PM | #81 | |
Rock Crawler Join Date: May 2008 Location: The Beautiful South
Thanks --actually, I just checked, and I have the XS3 FM radio. Do you know if it will work with that radio? Last edited by Master Basher; 06-09-2008 at 09:14 PM. | |
06-09-2008, 10:47 PM | #82 | |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
06-11-2008, 09:01 AM | #83 | |
To hell with it. I just ordered a DX3R. I'll sell everything else and keep my DX3.0 for when my brothers or friends wanna play with my trucks with me. Check out Ebay for a good deal on my old sh!t. | |
06-17-2008, 04:33 AM | #84 |
I dinked around with my linkage and my servo, and now I think I have the 'perfect' setup. I used leftover parts from a rear steer kit, and I get almost no twist at all on the linkage in any position. I'll post picks soon, but I'm tired once again, it's way past my bedtime.
06-18-2008, 12:18 AM | #85 |
Quarry Creeper Join Date: Apr 2008 Location: Garden Grove
| Lets look at it
I started to build mine. How much interlock do you need for the driveline to hold? I have about 1/4 on each male end when in 4 wheel. Not sure if it will hold the spline. Let me see some more pices.
06-18-2008, 03:16 PM | #86 |
| Left over link from a rear steer kit works the best for me. Doesn't twist at all, and looks 'stock'. |
06-18-2008, 09:23 PM | #87 |
Rock Crawler Join Date: May 2007 Location: lacey
does it twist if you put it in "dig" mode (rear tires locked) and try to run the truck forward on the ground? mine didn't really twist that much until I engaged the dig. no bueno. I do like the idea of using the bent rod ends though, makes for better geometry.
06-18-2008, 09:41 PM | #88 | |
I have yet to need anything but 4wd in any of my own crawling practice. I just wanted to make it because it sounded so cool to have the ability to do that, but it hasn't helped me yet. But then again, I've never been to any competitions to actual observe it's correct usage. I've only been to the local mountain and dirt/gravel piles. --oh, and your problem suggests that your metal pipe thread nipple still has peaks too high on the threads, or the bushings do, or the connection rod between the two male shafts has too much friction. Remember my post earlier where I said that it doesn't need to be threaded permanently into one of them? Check out the picture of the welding rod that I have miced (okay, they're calipers), it floats freely in both shafts. | |
06-19-2008, 02:20 PM | #89 |
I like the link you used too. No twist sounds good. My ball end idea seemed great but it does twist when locked in dig. I am using zip ties to keep it from rotating now, but Ill try the solid mount.
06-19-2008, 07:44 PM | #90 |
| I just flanked the ball end sockets with washers, and didn't tighten it too much, because they do still have to rotate when the servo moves. Don't use a ball end though, just use a screw with a nylock nut.
07-09-2008, 10:53 PM | #91 |
Rock Stacker Join Date: Feb 2008 Location: winnipeg
| great idea works great
Well its midnight and I just finnished this build. The only tuff part is treading the pipe, but I think I nailed it it works great thanks
07-09-2008, 11:14 PM | #92 | |
| use pot Quote:
07-27-2008, 08:00 AM | #93 |
Pebble Pounder Join Date: Jul 2008 Location: Phoenix, AZ
2 questions about the setup: -Is there any way to attach the linkage without welding? I was thinking maybe a short ball and socket like the ones used on the suspension or tie rods. -what effect does this have on the transmission? Is there enough slip in the tranny to allow that lockup, or did you do something there too? Look like a great, inexpensive setup, but I just want to make sure I'm not going to burn anything up on my new truck! Thanks |
07-27-2008, 09:46 AM | #94 | |
08-06-2008, 04:10 AM | #95 | |
The transmission is unaffected. You should go back and read one of my earlier posts that shows details of the parts before they're assembled, I even show caliper measurements. It took me a little while to figure out how it all worked too, but the design really revolves around a good straight smooth rod in the center of everything. | |
08-06-2008, 05:27 AM | #96 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
Glad to see some of you guys still using this. All the digs that I have seen in this thread look great! I finally got an R2D and am about to get a berg so I dont mess with these anymore. Keep up the good work guys!
08-25-2008, 09:05 PM | #97 |
Rock Crawler Join Date: Mar 2008 Location: hillbilly illinois
| Can I have your old one? I can't do it for the life of me lol Who wants to make me one? I'll pay ya. lol
08-31-2008, 07:17 PM | #98 |
Quarry Creeper Join Date: Jul 2008 Location: looking for that perfect setup
wat is the point of dig wat is it used for? |
09-04-2008, 06:12 PM | #99 |
Newbie Join Date: Sep 2008 Location: Medina
Great info in here. I watched the video and I was wondering what impact on performance the dig has when it moves the suspension. It seemed like when the dig locked the rear axle it also loaded the suspension. I would think this could possibly cause issues on the course? Keep in mind I have not Crawled (yet) but I am looking at all the options and threads and I thought I would ask about the dig system(s). Thanks, Chris |
09-04-2008, 10:08 PM | #100 |
Newbie Join Date: Aug 2008 Location: kennewick
nice way of doing it. i just forked out the money and bought the dna dig kit
