01-08-2010, 11:10 PM | #161 |
Rock Stacker Join Date: Feb 2009 Location: Caldwell, Idaho
yes i agree , i think i will build one
01-10-2010, 09:50 AM | #162 |
Quarry Creeper Join Date: Nov 2009 Location: East Greenville
so i noticed in the pics that the male shaft from the axles has pins on it? The stampede shaft i bought doesent have these on it, and ur picture at the top has the male shaft without the pins on it
01-20-2010, 01:20 PM | #163 |
Newbie Join Date: Nov 2008 Location: The Netherlands
I finished building the dig this weekend and it works great. It did take me some time to grasp the idea of how this dig works, but after careful reading this thread a couple of times I managed! Even though I had to do it twice (the first one was unusable)..... To give you guys an idea on my build I added two pics. Martin |
03-04-2010, 08:06 PM | #164 |
Newbie Join Date: Feb 2010 Location: Chattanooga
Looks really good! I like it! |
06-01-2010, 11:24 PM | #165 |
Rock Crawler Join Date: Apr 2010 Location: Kelowna, B.C., Canada
Newb question but is it possible to have front and rear dig this way. Also what kind of servo and how much torque does it need? Could a mini servo be used. Thanks
06-04-2010, 01:25 PM | #166 |
Yes, it is possible to have DIG on the front and back with this system. It won't be easy since you need to move your servos around. I have not seen pix yet so no help from me in that department. You can use this link for reference (go to the last page and download the PDF). Another option is to have DIG in the back and 4ws. I just saw it this weekend and it works great! The servo does not have to be strong in this set-up. I am using a Traxxas 2056 with the following specs: • 80 oz-in torque • Transit time 0.23 sec/60 Good luck! Martin |
06-04-2010, 01:25 PM | #167 |
07-09-2010, 08:20 AM | #168 |
Newbie Join Date: May 2010 Location: Groveland
it looks complicated. wouldn't it be easier to buy one that bolts on
07-09-2010, 11:18 AM | #169 | |
Rock Crawler Join Date: Jun 2010 Location: KCRC
how did you make up your connection at the sleeve? Is that just a 15-20mm hex screw tapped into the sleeve? i just can not tell the connection between the servo linkage screw and the screw tapped into the axle sleeve. i will be trying this...your set up is the cleanest looking in this thread, imo. thanks for any help, jeff | |
07-15-2010, 02:52 PM | #170 |
The screw in the sleeve is indeed simply tapped into the sleeve. The sleeve itself was thick enough so that the screw would go 5 times round (which is plenty for grip). Then with some Loctite it is secured enough. The screw itself is not a normal screw. I had the part AX30366 left because I used the axial universal joints: http://www.axialracing.com/ftp/ax10o...niv_joint.html I simply took the head of the AX30366 and used it to join the linkage with the sleeve. Obviously, you can also use a regular screw and drill a hole in it. However, I thought that needed more precision than I could give it. Hope it helps. Martin |
08-25-2010, 12:10 AM | #171 | |
Quarry Creeper Join Date: Sep 2009 Location: Vancouver,Canada
10-26-2010, 09:51 PM | #172 | |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
I am a Pipefitter by trade.......I think I know my sizes. I would also like to see you get a 1/4" bushing into a 1/8" pipe. P.S. A drive shaft wont fit into a 1/8" pipe. | |
10-29-2010, 06:16 PM | #173 | |
Quarry Creeper Join Date: Sep 2010 Location: West Linn
nice work, looks great. | |
11-14-2010, 05:23 PM | #174 |
Newbie Join Date: Oct 2010 Location: Canada
In the process of building my dig at the moment and wanted to see where the shorter of the two male shafts is used,trany side or diff side?
11-22-2010, 09:07 PM | #175 | |
Rock Stacker Join Date: Oct 2010 Location: home of the beaver
go back to post number 44 theres a pic of it there by the way thx for all the info from everyone i will be starting mine tomorrow | |
01-23-2011, 02:21 PM | #176 |
Newbie Join Date: Oct 2010 Location: West Part of the west side of the river of monroe
Love it. Seems sturdier than anything on the market. Might have to try this. |
03-09-2011, 09:34 AM | #177 |
Newbie Join Date: Mar 2011 Location: CANON CITY
03-09-2011, 05:32 PM | #178 |
Pebble Pounder Join Date: Mar 2011 Location: Humboldt
Looks like a fun project.
07-01-2011, 12:18 PM | #179 |
Newbie Join Date: Feb 2011 Location: TN
nice build
10-24-2011, 02:05 PM | #180 |
Rock Stacker Join Date: Oct 2011 Location: searcy
I really like the effort of building from scratch!! That takes alot so props to that!!
