01-20-2008, 10:57 PM | #1 |
Pebble Pounder Join Date: Nov 2007 Location: Bay Area
| broken outdrive shaft
So I'm running punisher shafts on my axial tranny and I got in a little bit of a bind and this was the end result anyone else run into this problem? |
01-20-2008, 11:06 PM | #2 |
Never seen that happen. Looks like a clean break.
01-20-2008, 11:44 PM | #3 |
yeah I was surprised myself, sucker just sheared right off.
01-20-2008, 11:51 PM | #4 |
Maybe just a bad part. Was that the rear output?
01-20-2008, 11:59 PM | #5 |
Rock Stacker Join Date: Oct 2007 Location: Yakima
Normally the shaft would have given up the ghost first, but those punisher sahafts are pretty solid......you are only as strong as your weakest link. Something has to give huh?
01-21-2008, 12:03 AM | #6 |
| It was the front output shaft, bought the replacement part already but I'm thinking maybe I should upgrade tranny's maybe a rc4wd? the axial outdrive seems to be kind of weak now that I've had a chance to really look at it.
01-21-2008, 06:28 AM | #7 |
Quarry Creeper Join Date: Nov 2007 Location: in the shop, of corse!
cant tell from photo..spot where the shaft sherred off ...is that a hole that goes through to inside diff? if so is it machined that way? if it is machened is it concentric n what size is it? got 2 AX-10 trans n dont want this happening to me so i am wondering is this a one off defect or a design flaw:? if its machined that already got fix in mind |
01-21-2008, 06:37 AM | #8 |
Quarry Creeper Join Date: Oct 2007 Location: PF, WI
I had the same thing happen to me and I was using stock shafts. The break looks exactly the same. I refused to pay $21 for the part so I drilled and tapped the broken piece to 5mm. Then I threaded a piece of 5mm allthread in there, ground a flat spot on it and havent had a problem since.
01-21-2008, 06:51 AM | #9 |
Quarry Creeper Join Date: Dec 2006 Location: Corbin KY
i have broken 3 off. I like the tranny awful good but it gets old breaking the same thing. I just got an R2D and havent looked bac since.
01-21-2008, 07:02 AM | #10 |
RCC Addict Join Date: Sep 2007 Location: Westland, MI
Damn, another strike against the Ax-10. I was thinking of using the trans in my next build. Oh well looks like I will use another R2. |
01-21-2008, 08:40 AM | #11 |
RCC Addict Join Date: May 2006 Location: China Grove, NC
This is not a strike against Axial, it is simply the weakest link breaking. I run 2 small Brushless motors on my Ax10, which I have previously busted CVDS in my TLT. I have stalled these out without any damage using a fully charged 3 cell lipo. The axial transmission and axles are very strong. (I am using TXT shafts, no they will not work in a single stock transmission Ax-10) |
01-21-2008, 08:59 AM | #12 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
EeePee taught me long ago "Weakest Link Theory 101". I'd rather pop a drive shaft (only done it once anyhow) in a competition and be able to fix it than break a transmission. Steel is stronger than the aluminum output shaft...doesn't take a genius to figure that out. |
01-21-2008, 09:09 AM | #13 |
Add bulletproofness...... Stainless steel Revo's |
01-21-2008, 09:37 AM | #14 |
I wanna be Dave Join Date: Dec 2006 Location: In Cali.
01-21-2008, 09:48 AM | #15 |
My vote for the next weakest part is the axle shaft.
01-21-2008, 10:05 AM | #16 |
I think the stockers would be alright if they aerent hollow in the center.
01-21-2008, 10:11 AM | #17 |
not gonn waste space w quotes ....ooooohhhhh........stainless!!! 316? maybe rc4wd can include it w trans case..that will make them fly off the shelves ...my vote for weakest link....driveshaft...easy 20 sec fix |
01-21-2008, 11:17 AM | #18 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
I rather have a driveshaft break then having the output shafts or a ring-n-pinion get munched. Two minute fix verses a major tear down.
01-21-2008, 11:33 AM | #19 |
01-21-2008, 11:40 AM | #20 |
| Raptorman! keep in mind that you are a awesome fab. man and the average joe might not have access to that kind of machining.
