01-21-2008, 06:18 AM | #1 |
Quarry Creeper Join Date: Mar 2005 Location: hudson (the big city)
| maxxed's new edge...
[here is my new edge. (thank you tcs)!!! i just got my panels cut out and painted over the weekend. need to take some goo gone to clean up the radio tray where the on/off switch is. -rooster crawler -integy 55t -traxxas tq2 -hot racing wheel wideners -proline moabs -internal springs (no droop setup yet) -axial bent links Last edited by madmaxxed; 01-21-2008 at 06:24 AM. Reason: add to description |
01-21-2008, 10:22 AM | #2 |
Newbie Join Date: Aug 2007 Location: tulsa
that looks kick A$$...but i think some black zip ties would make a huge difference. nicely done |
01-21-2008, 10:54 AM | #3 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
Why did you go with wheel wideners? just wondering
01-21-2008, 10:59 AM | #4 |
WOW that is green! Looks really good, I especially like the small panel you made for the rear that is a great touch. Yes, black zip ties! |
01-21-2008, 11:19 AM | #5 |
Newbie Join Date: Nov 2007 Location: Is this a trick question?
What springs are you running in your shocks? and how does it handle with that setup if you have driven it yet?
01-21-2008, 11:23 AM | #6 |
i'm running the edge hardware kit springs on top of the pistons with the oil that came with the axial kit. i've only run it in the house for a few minutes and i get a lot of body roll from steering and a lot of torque twist. i'll try a thicker oil. i've always like a slightly wider stance in all my rigs. the wideners i got have two different widths to choose from. i went with the less wide ones. i would have used black or even green zip ties but the hardware store up the street didn't have any. i wanted to do something with the back. i didn't want to leave it open. i really wanted to try to match the axial green components as best as i could. thanks for the comments...
01-21-2008, 11:25 AM | #7 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
Your getting all that roll cause its designed to be a full droop truck. Try that first, I think you will like it.
01-21-2008, 11:29 AM | #8 |
i'll definately give it a shot. i do like the added clearance with the springs on top but i'll give it a try...
01-21-2008, 11:49 AM | #9 |
The clearance is ok but the performance will suffer, a lower riding rig with a good COG will perform much better.
01-21-2008, 11:58 AM | #10 |
Rock Stacker Join Date: Jan 2008 Location: Joliet
Man that thing is sweet, I want an edge so much. You liking the moabs or? |
01-21-2008, 12:20 PM | #11 |
i couldn't tell you my opionion on the moabs yet. there is way too much snow here in new hampshire to even get to any of the crawling spots. i do believe the compound of the axial tires are a lot softer though. i'll have to try them both out come spring.
