01-28-2008, 05:09 AM | #1 |
| AX10 GC1 setup questions
I have had my GC-1 chassis for some time now. I am making some minor changes. Is anyone having issues where the upper links are hitting the shocks? This really limits my flex. I'm only getting about 3.5". I am running JPCustoms shocks. I did have my shocks on the outside of the axle link mounts and the upper shock mounts spaced out about an inch or so from the chassis. My tires would rub when turning and I was just trying to stop that. Mainly I'm just wondering where everyone is running their shocks. Here are some pics. |
01-28-2008, 05:20 AM | #2 |
Rock Crawler Join Date: Jan 2006 Location: commerce twp.
leave your shock mounts like they are on top, but the bottoms have to mounted on the outside of the axle mount, i have msd rims with the wide offset the tires do not hit they come close though, hope this helps.
01-28-2008, 09:21 AM | #3 |
Rock Crawler Join Date: Jul 2007 Location: central PA
You know the 2 holes on each top side of the axle tube? I have seen alot of guys make custom shock mounts that screw onto those holes. You could design it to locate the shocks where they need to be for you. Some flat aluminum plate would be easy and you could bend it however desired. Another thing I spotted was the green little spacers you have inbetween your upper links and chassis. Not sure if you need them to prevent binding, but removal would prolly give you a little more clearance. |
01-28-2008, 09:49 AM | #4 |
| Thank for the input guys.......Guess I'll just move the shocks back to the outside and let them rub.....It wasn't causing any issues, but I have caught it once when the tires pulled the spring up far enough that the lower spring keeper came out. I just put a little bit more preload on the springs.
01-28-2008, 09:50 AM | #5 |
| Yeah that spacer gives me just enough room to prevent any binding.
01-28-2008, 11:17 AM | #6 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
Have you tried moving your uppers at the chassis to the inside? Just wondering if it would change the suspension much and looks like it would quit rubbing.
01-28-2008, 11:30 AM | #7 | |
I wanna be Dave Join Date: Jul 2006 Location: Moscow Mills MO
he tried that last night, but it would let the axle sway because it slightly lets the uppers go / \ the same way as the lowers. | |
01-28-2008, 12:57 PM | #8 |
01-28-2008, 01:18 PM | #9 |
RCC Addict Join Date: Oct 2007 Location: Auburn
As Hildy commented see if you can find some of the TLT axle mounts. You have to drill 1 hole centered between the 2 existing. then it will mount to the Axial top holes. This gives you ride height and flex. Also you can do a simple BTA with no mods. Austin has already put the holes there thinking forward. Not really but it just sounds good Look in the Vendor thread and I posted some pics of the BTA you should also be able to see the shock mounts there. Feel free to PM me if you have any other ???'s |
01-30-2008, 07:04 AM | #10 |
Quarry Creeper Join Date: Aug 2006 Location: On A Big Pile Of Rocks
I can help you, I have a GC-1. shocks go out side of the mount in the rear ONLY, in the front they go were they are suppose to. the front shocks at the top needs to be spaced farther apart, when looking at your photos your shocks taper in at the top, you want it the other way around then you want have any more problems with the shocks.Chimney
01-30-2008, 07:31 AM | #11 | |
I think he had it that way and when his wheels turned, they hit his shocks. | |
