RCP Straight Axle Adapters Has anyone noticed that when these are installed only 1 bearing can be used and you get a lot of slack in the wheel? Looks like the straight axles would be needed to resist the extended wear and tear factor. |
If you want to run the stock parts add a small piece of fuel tubing in the outer axle cup. This will force the stub axle into the bearing eliminating slop. Even with the 2 bearings the slop would still be there. |
aren't the axle adaptors and straight axles made to be used in conjuntion with each other? Why would you use the adaptors with the stock doggies and cups? |
i have the stright axles and adapers and there is zero slop none at all. |
Can be used with stock axles and bearings. __________________ But after just 1 battery ,you will find alluminum debri inside.:shock: The stock axles rub BADLY.:-( Being a machinist,I must say your guy's parts are top notch in fit and finnish. In my opinion your should give a guy some kind of warning to also use the straight axles with the lockouts.I made a set,and can say with the straight axles there is NO slop in the rear end at all."thumbsup"Again you guys do top notch work and have the best shipping ever.A little warning on this issue would be nice for other customers. And where's my stickers???? How are we supposed to represent ?? :lol::lol: RCP ROCKS !! |
Guess, I should have went with best functional item and not by best looks. :-( |
Just ordered some RCP straight axles...........;-) |
2 Attachment(s) Well, I ran for about 20 minutes today (still waiting on the RCP straight axles). I pulled the straight axles adapters off and here is what I saw. The adpaters have a worn spot (cannot see in the pics to well) about 1/8" or so where the end of the axle cup ride. I cannot believe that RCP would sell these and not strongly advise that the straight axles are required to prevent excessive wear. |
I install twoo bearins on each side of mine. One in the bearing cup of the axle and another in the aluminum peice from rcp. No slop and works great. |
Mine did that while I impatiently ran it without the SS straight axles. Installed SS Straight axles now and its all good :) |
i ordered on monday and haven't seem mine yet. hopefully tomorrow. I can't wait to install that. the rcp knuckles and c-hubs and try my new Spektrum. does anyone know if RCP automatically ships stickers or if you have to request them? |
