01-31-2008, 11:51 AM | #1 |
Pebble Pounder Join Date: Sep 2006 Location: keller
| 96t Spur gear?
I am looking for a 96t spur or bigger if it is possible does anyone know were can i get one ? Last edited by hijack; 01-31-2008 at 12:02 PM. |
01-31-2008, 01:04 PM | #2 |
Pebble Pounder Join Date: Jul 2006 Location: Universal City
01-31-2008, 04:06 PM | #3 |
Pebble Pounder Join Date: Nov 2005 Location: NKY
01-31-2008, 08:08 PM | #4 |
Newbie Join Date: Jan 2008 Location: Salem
you have to get the Kimbrough, the dowels in the spur gear plate dont line up to the hpi style gear,
02-01-2008, 12:55 AM | #5 |
Rock Crawler Join Date: Jul 2005 Location: Rathdrum, ID USA
02-01-2008, 09:09 AM | #6 |
02-01-2008, 09:23 AM | #7 |
Quarry Creeper Join Date: Dec 2007 Location: Monterey, CA
Are you running the axial tranny? I run the 90t Kimbrough, barely clears the rear output. This is AX10 forum, did I miss something or does everyone know you run a stampede setup? |
02-01-2008, 09:49 AM | #8 |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
| i dont see where it says the original poster has a pede... since its in the axial forum.. id only asume that he has an ax-10 |
02-01-2008, 01:23 PM | #9 |
Newbie Join Date: Dec 2007 Location: Omaha
If you had to buy a gear why not get one you don't have to drill. I bought both the 90 and 93 Kimbrough spurs in the same order since some said they had trouble with the gears clearing the drive shaft coupling. I was able to get the 93 on and still have about 1mm of clearance. I bet the 96 would clear too.
02-01-2008, 07:31 PM | #10 |
Newbie Join Date: Jan 2008 Location: Sheridan
90T is probably the max for the AX 10. I tried a 93T, and it scored my outdrive. Why they gave the info for 90T + is beyond me.
