01-31-2008, 02:09 PM | #1 |
Newbie Join Date: Jan 2008 Location: Galt,CA Flat cow land
| Yet another failure
I really starting to think about just sticking to real 4wd's. This damn thing is costing me just as much Truthfully, I really dont think that I am being that hard on this AX-10. While in the back yard today, the rear wheels deciced that they dont want to turn with throttle now. I disasembled the rear diff and nothing is broken, but I can hold the rear tires, give it some throttle and I can feel something giving way in the rear diff. Driveshaft spins fine Grab both tires and go oposite ways with them, nice a solid. Rules out locker Ring and pinion are not broken Could the pinion and ring gear not be meshing? It's hard to determine that when the only way to check it is the axle assembled The only thing I can see is that there is abit of movement from where the bearing rides on the axle housing side to side. I cant find anything to shim it over. But it doesnt seem to be enough movment that would cause a problem. Please give me some helpfull advise, before it becomes a lawn orniment |
01-31-2008, 02:11 PM | #2 |
Tighten your wheel nuts.
01-31-2008, 02:13 PM | #3 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
You have broken your wheel hex's, $10 buchs says that there are tiny cracks in the point of the hex. Either get some aluminum rims, or glue in the plastic hexs.
01-31-2008, 02:15 PM | #4 |
Yeah, sounds like the wheels are slipping on the hex drives or the hexes are slipping on the pins.
01-31-2008, 02:17 PM | #5 |
Pebble Pounder Join Date: Dec 2005 Location: Yorkshire, UK.
Checked your wheel hexes? Might not twist with your hands but with the motor torque and wheels bound up they might slip. Another thing, check the hex pins are still in there. I had a front hex come loose which loosened the wheel nut leading to the pin coming out. Luckily i was on the kitchen floor. |
01-31-2008, 02:18 PM | #6 |
he beat me! |
01-31-2008, 02:20 PM | #7 |
Wheels are fine, I can spin the wheels by hand and watch the outer axle stub shafts turn also. It is definatly something internal. I just cant see exactly what is going on inside the axle.
01-31-2008, 02:22 PM | #8 |
I also assembled as much as posible with the axle shafts into the locker assy and twisted them as hard as I could and it is solid.
01-31-2008, 02:24 PM | #9 |
Well then just take the thing apart!
01-31-2008, 02:30 PM | #10 | |
The fawkin drivline set screw had backed out. I did use loc-tite when I installed the Max d-lines, but evedently not enough. DOH!!!! Thanks for the other info guys, I guess I tend to over analize | |
01-31-2008, 02:32 PM | #11 |
01-31-2008, 02:47 PM | #12 | |
Rock Stacker Join Date: Oct 2007 Location: Yakima
01-31-2008, 02:53 PM | #13 |
01-31-2008, 02:56 PM | #14 |
Quarry Creeper Join Date: Jan 2008 Location: Citrus Heights
Dont feel too bad I had the same thing happen, same parts and situation exactly, but I compleatly dissasembled it, and put it back together to figure it out |
01-31-2008, 02:58 PM | #15 |
Rock Crawler Join Date: Nov 2007 Location: Dayton, Ohio
Same thing happened to me. I could pull on it a little and it wouldn't slip off the shaft but it was loose enough not to hold. Glad it was an easy fix for you!!!
01-31-2008, 03:01 PM | #16 |
Newbie Join Date: Sep 2007 Location: in a house
Damn! That set screw was the first thing I thought of but ya beat me to it. Yeah those little guys like to back out on me too.
01-31-2008, 03:05 PM | #17 |
Rock Crawler Join Date: Jun 2007 Location: Flint/Mt. Morris
Everyone does it dood, but I feel you might still catch it, theres a few smartasses viewing the thread....
01-31-2008, 03:15 PM | #18 | |
This is the Pirate4x4 site of RC's | |
01-31-2008, 03:18 PM | #19 |
Yeah its the loudmouth ones that cry lol. So the inside of the maxx output is bigger than the diff pinion right? Someone needs to chime in with the part numbers for the smaller ID shafts, I cant remember which ones are the smaller ones.
01-31-2008, 07:46 PM | #20 |
Pebble Pounder Join Date: Jan 2008 Location: Rancho Cucamonga
funny thing is i have the same problem....but the front drive shaft is pulling out the bearing???? ill see if the clips are coming off the diff, but the set screws on the drive shafts keep coming out is getting reallllllllllly annoying. i dont want to step up to red lock tight because i want to take it apart sometimes........
