01-28-2008, 01:02 PM | #1 |
| RCP Straight Axle Adapters
Has anyone noticed that when these are installed only 1 bearing can be used and you get a lot of slack in the wheel? Looks like the straight axles would be needed to resist the extended wear and tear factor.
01-28-2008, 01:08 PM | #2 |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
If you want to run the stock parts add a small piece of fuel tubing in the outer axle cup. This will force the stub axle into the bearing eliminating slop. Even with the 2 bearings the slop would still be there.
01-28-2008, 01:17 PM | #3 |
01-28-2008, 09:50 PM | #4 |
Quarry Creeper Join Date: Dec 2007 Location: ON THE "EDGE"
aren't the axle adaptors and straight axles made to be used in conjuntion with each other? Why would you use the adaptors with the stock doggies and cups?
01-28-2008, 10:05 PM | #5 |
Pebble Pounder Join Date: Jan 2008 Location: Rancho Cucamonga
i have the stright axles and adapers and there is zero slop none at all.
01-29-2008, 05:04 AM | #6 |
| RCP AX10 black anodized straight axle adaptors (1 pair). The best way to lock out your rear axle without linkage. Great performance and great look for scale rigs. Can be used with stock axles and bearings. |
01-29-2008, 08:04 AM | #7 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
| Can be used with stock axles and bearings. __________________ But after just 1 battery ,you will find alluminum debri inside. The stock axles rub BADLY.:-( Being a machinist,I must say your guy's parts are top notch in fit and finnish. In my opinion your should give a guy some kind of warning to also use the straight axles with the lockouts.I made a set,and can say with the straight axles there is NO slop in the rear end at all.Again you guys do top notch work and have the best shipping ever.A little warning on this issue would be nice for other customers. And where's my stickers???? How are we supposed to represent ?? RCP ROCKS !! Last edited by Cave Dave; 01-29-2008 at 08:39 AM. |
01-29-2008, 08:54 AM | #8 |
Guess, I should have went with best functional item and not by best looks. :-(
01-29-2008, 09:01 AM | #9 |
Just ordered some RCP straight axles........... |
01-29-2008, 09:03 AM | #10 |
01-29-2008, 09:09 AM | #11 |
01-29-2008, 09:30 AM | #12 |
01-30-2008, 07:06 PM | #13 |
Well, I ran for about 20 minutes today (still waiting on the RCP straight axles). I pulled the straight axles adapters off and here is what I saw. The adpaters have a worn spot (cannot see in the pics to well) about 1/8" or so where the end of the axle cup ride. I cannot believe that RCP would sell these and not strongly advise that the straight axles are required to prevent excessive wear.
01-30-2008, 07:32 PM | #14 | |
01-31-2008, 07:17 AM | #15 |
Rock Stacker Join Date: Sep 2007 Location: SAN JOSE
I install twoo bearins on each side of mine. One in the bearing cup of the axle and another in the aluminum peice from rcp. No slop and works great.
01-31-2008, 08:00 AM | #16 |
01-31-2008, 08:22 AM | #17 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Mine did that while I impatiently ran it without the SS straight axles. Installed SS Straight axles now and its all good |
01-31-2008, 09:15 AM | #18 |
01-31-2008, 08:52 PM | #19 |
i ordered on monday and haven't seem mine yet. hopefully tomorrow. I can't wait to install that. the rcp knuckles and c-hubs and try my new Spektrum. does anyone know if RCP automatically ships stickers or if you have to request them?
02-01-2008, 05:59 AM | #20 |
| They normally don't.....I just requested some. I think all vendors should include some with orders over $50.
