ax10 shocks is there a good internal spring shock with a smaller dia. than the stock shocks |
TCS sells internal shock springs,look at the bottom of the page and page 2 http://www.tcscrawlers.com/AX10-Scor...p-1-c-283.html |
medium is too soft for the rear. the meds are perfect for the front but I haven't found stiff enough springs for the rear. I am using a medium spring and a half in the left rear to try to combat the torque twist. I also run a small half inch spring under each piston to lower the ride height. works pretty well. |
Losi mini t springs work |
i got set of pen springs(well there the size of pen springs), i cant remember exactly what there were caled |
pen springs are too small if you are going to go sprung. they work for droop because the the shaft holds it in place. I don't think they will work on top of the piston. Ideally, I would like to find a medium strength spring the length of the axial shock body. I would cut it in half and put half above and below the piston. I bought a couple bulk packs of springs from home depot, only 2 of them fit inside the shock body but they were to stiff and too short. guess I'll keep looking. anyone know the length on the mini t springs? |
