02-03-2008, 09:12 AM | #1 |
I joined the Band! Join Date: Dec 2007 Location: cotati
| ax10 in progress here are some pic's of my ax-10 rock rider tube chassis with stock tranny stock tranny and tranny plate fit nicely inside the chassis with no mods. i have since added the r2tranny w/ disconnect novak crawler esc and 55t motor straight axle adpt and axle,s by rcp and the clockable nuckles and hub carriers bent links losi rock claws custom carbon fiber battery plates made by JPH (jakes performance hobbies) |
02-03-2008, 10:24 AM | #2 |
Newbie Join Date: Dec 2007 Location: Galt (Sacramento)
that looks h3lla sick bro how does that link connector plate work on the rear axle ive been looking at a few different ones like the tcs one and do what kamikaze did to adjust the squat on my new axial moonbuggy thats under wraps
02-03-2008, 10:31 AM | #3 |
Pebble Pounder Join Date: Jan 2008 Location: Lanexa,Va
where do you get that tuber chassis?
02-03-2008, 11:16 AM | #4 |
| http://www.rcrockcrawling.com/index....6cab84b64ac771 that is the link for the chassis and the rear link plate works great the other kind that is flat and the links mount on the bottom side i found that the links bind a little bit when in a good twist more pictures to come |
02-03-2008, 11:42 AM | #5 |
so this would work with a wheely king?
02-03-2008, 12:00 PM | #6 |
i belive it was designed around a TLT-1 and trex it has a lot of mounting holes so i figured it would work with ax-10 axles took a lot of trial and error but the end result came out very good |
02-03-2008, 12:18 PM | #7 |
its alot of money for it though
02-03-2008, 02:57 PM | #8 |
nowhere near as much as the hustler
02-04-2008, 04:30 AM | #9 |
thats true
02-04-2008, 07:50 AM | #10 |
rock rider has so many spots to mount links and shocks where the hustler only gives you one option rock rider can be set up sprung or full droop |
02-04-2008, 09:39 AM | #11 |
well here are some pictures almost done a little more work on the shocks, maybe new ones maybe relocate the ESC |
02-04-2008, 09:41 AM | #12 |
02-04-2008, 09:45 AM | #13 |
02-04-2008, 11:17 PM | #14 |
RCC Addict Join Date: Dec 2007 Location: Calgary
thats badass
02-08-2008, 04:35 AM | #15 |
Pebble Pounder Join Date: Jan 2008 Location: foothills of va.
nice looking ride, i like the truck bods more, but the tubers look more to scale & right at home on the rocks. good job |
02-09-2008, 01:41 PM | #16 |
Rock Stacker Join Date: Jan 2008 Location: Escondido
I just bought a chassis from RC4WD like this, They're in Back Order, I might trade it for the Copperhead if I can use the links from my Scorpion, But it's hard to get an answer form these guys.
02-09-2008, 01:59 PM | #17 |
Rock Crawler Join Date: Dec 2007 Location: Ventura, Ca
Have patience, RC4wd is busy as heck these days. Might take a few days but they will respond. I have had very good customer service from them in the past. Even when things go wrong they will do their best to make it right. I was looking at thos chassis's as well, the copperhead looks promising. Its one of the MrPinks designs. If you watch the for sale threads he sell one once in a while. I almost bought the last one he posted but I had just got my BlackJack setup............
