02-04-2008, 01:42 PM | #1 |
Quarry Creeper Join Date: Aug 2007 Location: United States
| Axial's New Products.
Well, there are some new products out. The aluminum axle lockouts are a bit over priced, and I'm not to sure about the plastic ones. I think I would rather stick with my RCP lockout and straight axles. As for the slipper clutch it does not seem right to run a slipper on a crawler. I am hoping these lockers they have come out with will be much more durable, I guess we will see. Wheel hexes, hmmm I have never had a problem with mine, but maybe others have. I'm not sure if i will try the Axial lockers, I think I will wait for the boys over at RCP to come out with their steel lockers. (RCP ROCKS!) Either way I have to give it to Axial for trying to meet the wishes of the customers and how they keep improving this vehicle. They should sell a scorp with all of these upgrades that come with it. Josh |
02-04-2008, 01:55 PM | #2 |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
02-04-2008, 01:59 PM | #3 |
Ah, the link might help. Thanks Jason. What is the metal that these lockers are made out of?
02-04-2008, 02:10 PM | #4 | |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Made from strong sintered metal. Sintered metal provides superior metallurgical characteristics and can be manufacuted with very tight tolerances. As an engineer all that says to me is it is Sinter forged at best. It COULD be stronger or weaker than stock, as 6061 billet is a decent material all in all. One benefit will be how it engages to the axle, sinter forging holds a better tolerance on odd shapes like the axle input hole than machining can. | |
02-04-2008, 02:16 PM | #5 |
Quarry Creeper Join Date: Sep 2006 Location: Orange, CA
The rear axle lockouts are the smallest on the market, after our last comp I still had scratches on mine so anything larger is only going to have less clearance. They will also work with the RCP stainless steel axles. The slipper clutch can be locked completely, the major benefit is the reduced gear wobble you get with the plastic gear holder. The locker is made from Sintered Metal which is a form of steel. It also helps to reduce some of the play you get in the drivetrain from the stock locker. Also keep in mind that the prices shown are list prices and will be comparably priced with competitors product out on the market now once they hit the street. Thanks, Axial |
02-04-2008, 02:22 PM | #6 |
Pebble Pounder Join Date: Nov 2005 Location: NKY
How long until we will see these for sale?
02-04-2008, 02:27 PM | #7 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
how about some different size spur gears. Also when are the CVA's going to be released? Last edited by yotachump; 02-04-2008 at 03:46 PM. |
02-04-2008, 02:58 PM | #8 | |
02-04-2008, 03:39 PM | #9 |
Pebble Pounder Join Date: Jan 2008 Location: high point
i like that stuff,great price for the hexxes.all others are 12. to 14.dollys,so way to go axial |
02-04-2008, 03:50 PM | #10 |
RCC Addict Join Date: Sep 2007 Location: WHEAT RIDGE, CO
Axial: Looks like some nice goodies........the slipper will help the drive train last forever.......saw you and Jason at finish-line in denver blowin parts...i've had my own Traxxas slipper installed and have "NO" drivetrain breakage at all.........that slipper looks nicer i'll have to get one plus the locker if truely heavier than stock.........Thanks for the up-grades and keep up the great work!! |
02-04-2008, 04:44 PM | #11 | |
Rock Stacker Join Date: Aug 2007 Location: Canada
rc4wd at TCS axial Rear lock out (alu) 29.99 35.00 Straight axle 24.99 20.00 Total 54.98 55.00 The Axial does require the use of the straight shaft tough and the RC4WD just recommended them René | |
