02-06-2008, 02:58 PM | #1 |
Quarry Creeper Join Date: Feb 2008 Location: on the edge of sanity
| my setup
well this is what ive got for a setup so far as what to get, im short on money and think this will do for now, ive got to buy it a peice at a time so it might take a while, any suggestions or anything i left out(i know i got a radio already) feel free to coment , is a tranny with a dig setup worth the money, and wht is the reason for putting the tires on backwards?? CKRC (4) 120mm Threaded Aluminum Shock set Axial Scorpion CKRC Stage 2 Kit With Ax10 TCS "Edge" AX10 Scorpion Direct Bolt on Tube Frame tires and wheels and suspension A1 Stick On Wheel Weights AX8111 Axial 2.2 Standard Beadlock ring, Red AX8097 Axial 2.2 8 Hole Beadlock Black AXA015 Axial Cap Head M2x10mm Beadlock Screws (10) CKRC (2) 120mm Threaded Aluminum Shock set (ax10) Team Losi Rock Claw 2.2 tires tranny and drivetrain R2 Tranny Steering Kit R2 Black Tranny with Disconnect AX10 Drive shaft Upgrade Kit For Axial Scorpion AX10 HD Yokes Upgrade for Axial Scorpion CKRC 7 Tooth 32 Pitch Long Pinion Gear TCS Aluminum Axle Plates for Axial AX-10 Scorpion (2 each) TCS Delrin Upper Link/Servo Mount for Axial AX-10 Scorpion (1 each TCS Aluminum Boomerang Upper Link Mount for Axial AX-10 Scorpion electronics Thunder power TP-535 Lipo Charger #175 Vislero 1300 3s lipo battery Holmes Hobbies Revolver Black #117 Castle Creations Mamba Max #31 Hitec Aluminum Servo Arm HD 1" 35955S Hitec Hs5955tg Digital Ultra Torque Servo 6 Cell 1500 AX10 Crawler Pack With Tamiya Plug Axial ax30041 Velcro Battery Strap Kit Soldering Iron 60 Watt Tamiya 7.2V Connector Set 50106 Trinity Servo Tape Wide 1302 Deans Male Ultra Plugs (2) 1303 Deans Female Ultra Plugs (2) Deans 12GA WET NOODLE/2'RED/2'BLK #1410 |
02-07-2008, 09:48 PM | #2 |
Rock Crawler Join Date: May 2007 Location: Salt Lake City
Wow nice list of goodies. Yes an r2d is worth it because it enables you to climb things that normal 4wd would not and putting the rear tires on backwords also helps the front tires that are running normal direction hold on to the rocks so you dont tip backwords. Dont forget to put the castle creations BEC on your list if you are running two servos. You have a lot of testing to do. Good luck!
02-07-2008, 10:02 PM | #3 |
Debunking old stereotypes Join Date: Feb 2006 Location: 1st and Amistad
02-07-2008, 10:08 PM | #4 |
Pebble Pounder Join Date: Aug 2007 Location: Anaheim/Gardena, CA
Give him a break... He's new Nice Part List. |
02-07-2008, 10:23 PM | #5 |
02-07-2008, 11:06 PM | #6 |
Rock Crawler Join Date: Jan 2008 Location: Cotati
