02-12-2008, 07:12 PM | #1 |
Pebble Pounder Join Date: Jan 2008 Location: Woodinville, Washington
| tubbing for rear steer?
Hi, I've looked at countless posts of people and their rear steering linkage on their ax-10's, and I just recently got my ax-10 and I want to make my own rear steering linkage. All I need to know is what tubbing to use, and where I can get it (home depot, shucks, napa, large hardware stores?). Thanks a bunch to who ever can tell me |
02-12-2008, 07:53 PM | #2 |
Quarry Creeper Join Date: May 2007 Location: Seattle
You can get it at any hardware store, or in this area, any hobby shop. Most hobby shops sell K+S brand tubing. Unsure which size exactly, I used the same size that fit my ends...and I used 4-40 all thread, most people say to use 6/32 but I have had no issue with 4-40 pulling out or breaking. |
02-13-2008, 10:32 AM | #3 |
I wanna be Dave Join Date: Jun 2007 Location: Canada, eh.
x2 on the K+S aluminum tubing. 1/4" outer diameter, and whatever inner diameter that can still fit over 6-32 allthread. Can also go with 1/4" brakeline (bit cheaper). I'd recommend using 6-32 allthread. Cheaper (can get it at hardware stores whereas 4-40 I've only found in hobby shops), easier to find (at least for me it is), and just as easy to work with, plus you get some additional strength. If you go with 6-32 and are using Axial or Traxxas Maxx rod ends, you'll need to drill them out slightly to get the rod to thread in.
02-13-2008, 10:37 AM | #4 |
Rock Crawler Join Date: Dec 2007 Location: Ventura, Ca
I just ordered extra axial links, cut it to size and tapped it.
02-14-2008, 07:12 PM | #5 |
thanks to you both, the only issue that i've thought of, just a precaution is, what about tapping the inside of the tube, like, will it be a good size hole or is it going to be a small hole that will be able to be tapped. If its a bigger hole, what should i use to fill in the tube, to be able to tap it?
02-14-2008, 08:08 PM | #6 | |
Quarry Creeper Join Date: Sep 2007 Location: Elizabethtown,KY
02-14-2008, 08:45 PM | #7 | |
Debunking old stereotypes Join Date: Feb 2006 Location: 1st and Amistad
Why tap anything? Just use allthread straight through, and sleeve it with the tube. Pretty simple. Personally, I like beefy links, I use 8-32 allthread, and the big Jato ends, they fit perfect. Last edited by freetimecrawler; 02-14-2008 at 08:47 PM. | |
02-14-2008, 10:23 PM | #8 | |
Thats the same thread as stock | |
02-14-2008, 10:40 PM | #9 | |
RCC Addict Join Date: Aug 2005 Location: VARCOR
Jato/Revo rod ends [turnbuckles] are easily obtainable through various vendors here, through other online retailers, or through your LHS. Stop by Lowes and pick up some 8-32 all-thread for a few bucks. Then hit up Napa [or whatever auto parts retailer] for some 1/4" brake line for a few bucks. Tools needed: Standard sized crimping tool with thread cutting grooves, pipe cutter/hacksaw, and a couple of thingies that fit well into the eye openings of the rod ends [phillips head screw drivers]. With some measurements, cut the thread and tube to length. Then start to thread one end of the all-thread into one rod end, stop, install tubing over all-thread, begin to thread other rod end onto other end of all-thread .................. then twist together both rod ends using an appropriately sized tool to fit into the rod-end eye [phillips head screwdrivers, etc]. To be honest, for whatever reason, I can't drill/tap a hole accurately in the center of a piece of rod to save my life, so I stick with the allthread/tube method of making links, and so far, I have no complaints about it. | |
02-15-2008, 12:11 AM | #10 |
Rock Crawler Join Date: May 2007 Location: lacey
these work great for the FRONT steering on my 10lb super. building the ULTIMATE links easy, strong, cheap. plus you can brag that you have carbon fiber links! |
