02-20-2008, 09:04 PM | #1 |
Quarry Creeper Join Date: Feb 2008 Location: Hudson
| NEW!! My AX10 project and my EDGE tube frame WITH LIGHTS!!
Hi All I am really new to Crawling and new to this website. My Name is Brian and I from New England and have been looking here for some time now. So I figured It was time to post something that I have been working on. Let me know what you think. It is a project in progress. Also I have ordered a few of the new style upper link mounts as well as new servo's and still going to be buying some more upgrades as time goes on. Like Lipo's and charger, new reciever, beadlocks, tires..... Here is my original set up and my 1st ever custom made battery pack to fit over front axles. As well as my home made roll cage and my old RC body with my custom USAF paint theme. haha Started some detail on my Ax10 boddy So thats what I have done so Far. I am wairing on a metal shear / brake combo that my g/f's mom bought me for my bday so I can make all my own custom side panels from aluminum. Also this thing has some nasty articulation huh!? haha Took me a while to set it up like that and I just hope it works good in the rocks. I have yet to try my ax10 in the rocks at all. :-( I bought it in the winter so there is no rocks yet haha. soon very soon. Last edited by 4x4Crawler4LIFE; 02-24-2008 at 09:08 PM. Reason: new stuff inside Lot's of pictures |
02-20-2008, 09:19 PM | #2 |
RCC Addict Join Date: Jun 2004 Location: ORegon
i really like that grill material you used on the roof. what is that? you are going to want to limit your articulation alot. the max you'd want is like 70 degrees. even then that is quite a bit.
02-20-2008, 09:26 PM | #3 |
Pebble Pounder Join Date: Jan 2008 Location: Rancho Cucamonga
yeh limit your articulation severly, mine was like that and would just dig its self into a problem, twist itsself into a pretzel!! but hey good luck
02-20-2008, 11:18 PM | #4 |
Quarry Creeper Join Date: Dec 2007 Location: At the Gates
im going to make a prediction.....ready: the first time you get that thing on the rocks, your gonna get home and change a lot of things |
02-21-2008, 06:05 AM | #5 |
Yeah I had a feeling the thing would get twisted when I take it out the 1st time. And I know that I will be doing a lot of work to it still. The metal on the roof was just some scrap metal from my work. It was from a Hard Drive Filler slot cover. Cut it and grinded it made it fit, Might use it may not. Also I have the rubber bumpers that came on the shocks to use on the outside. and I put them on the inside and the reduced my Articulation, so I took them out. haha. So your saying I should probably still want to put them back in huh.? Also I have the shocks mounted on the inside with a few washers because without the washers when i would twist the chassis my shock tops would pop off? Probably because there as too much articulation huuh? A quick question about the shocks as well. I bought the shock kit from TCS and it came with some internal springs. So that is what I have installed. It is sitting like high up like it normaly would. but i saw a sweet one just like mine on youtube and it was sitting really low. Almost like he had no springs inside and he said he was running 30% oil. is that a good thing to do? no internal or external springs and just run a little oil? Thanks for looking. and thanks for answering any of my questions. Last edited by 4x4Crawler4LIFE; 02-21-2008 at 06:33 AM. |
02-21-2008, 08:35 AM | #6 |
Rock Crawler Join Date: Nov 2007 Location: Dayton, Ohio
Use some nitro fuel tubing on the shock shafts inside your shock to limit the travel, I will put about 1/2" to 3/4" on the inside of each shock. Put the spring TCS gave you on the inside under the shock piston so the spring is pulled back into the shock shaft instead of pushed out (it's called a droop suspension). This will lower your center of gravity a lot and and it's what the Edge chassis was designed for so it handle better on the rocks. |
02-21-2008, 08:47 AM | #7 |
Rock Stacker Join Date: Nov 2007 Location: Tenino
I like the roof panels, very nice work!
02-21-2008, 10:29 AM | #8 |
ok man thank you thank you thank you for that tip. here I am thinking I set them up right haha. well time to take off the shocks again haha. for like the 4th time. |
02-21-2008, 10:30 AM | #9 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
A good crawler is all about low center of gravity not 90* of flex. Limit some of that flex and get your weight as low as possible and you'll be better off. |
02-21-2008, 10:51 AM | #10 |
Glad I could help.
02-21-2008, 11:14 AM | #11 |
so is this what you mean? I left work sick today so I figured I could try it out haha EDIT removed old pic and replaced with this one that shows what I removed. Last edited by 4x4Crawler4LIFE; 02-21-2008 at 09:36 PM. |
02-21-2008, 11:44 AM | #12 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
The tsc springs go under the piston.
02-21-2008, 11:48 AM | #13 |
Newbie Join Date: Feb 2008 Location: Locust Grove
That is a nice crawler you have there. I like the body choice also.
02-21-2008, 02:33 PM | #14 |
Quarry Creeper Join Date: Dec 2007 Location: ON THE "EDGE"
there's no point in the lower spacer. the compressed spring acts as a limiter.
02-21-2008, 02:48 PM | #15 |
True that on the lower spacer bushing, wasnt thinking that. just saw a pic of someone elses like that on here and figured i would try it. well now there is a spacer in all of mine haha so i am just going to leave it in there. Unless I get a set of 4 softer inside springs? in a droop is it better to go soft or stiff? hmm. well I have the medium ones in there now. Here is a current pic. Just finished installing all the shocks again. Much better and Lower center of gravity now that I have the springs in there right. Also you can see that my articulation is much less now. so this is the most it will twist now before lifting the rear tires This is waht all you said to do right haha :O) Think I like it better this way as well. I was looking on youtube and a few kids have way to much articulation and it was causing the rear end to not be very cooperative. Here is some of the image designs I decided to play with just for fun. I think I am going to do something else I just thought it looked cool all green. I just used Paint brush and fooled around with TCS's designs. Currently I am waiting for my 2 more Bent links to come in the mail as well as the upper link mounts. Comments welcome. can't wait to finish this and get to crawling. Last edited by 4x4Crawler4LIFE; 02-21-2008 at 09:39 PM. |
02-21-2008, 04:17 PM | #16 |
Pebble Pounder Join Date: Jan 2008 Location: Oak Harbor
About the articulation; you just have to try different setups on the places you will be driving and see what works. Also, your driving stlye will affect how you will wnat your truck set up.
02-21-2008, 04:32 PM | #17 |
Newbie Join Date: Dec 2007 Location: alvarado
like the wood bed floor!!!
02-21-2008, 05:39 PM | #18 |
Quarry Creeper Join Date: Dec 2007 Location: St. Louis
Nice looking rig! you have a pm |
02-21-2008, 09:28 PM | #19 |
Hi I thought I could share my funny trick I was playying with when i first got my ax10 and before I started installing my edge chassis. check out the "moon walk" along with a few of my other vids on youtube. I will be getting out on the rocks someday soon when i complete this project and I will make some more fun videos. Also if you are into youtube add me as a friend I dont have any haha tty all later http://www.youtube.com/watch?v=VGCJOZ5o_v8 |
02-22-2008, 08:24 PM | #20 |
got my bent links in as well as the upper link mounts. just playin garound with my extra green spacers, I still have to look back onto TCS and see how to mount the links to try to eliminate the torque steer. |
