02-21-2008, 08:46 PM | #1 |
RCC Addict Join Date: Nov 2007 Location: CALI "209"
| are ther any benifits of running bent links in front?
is there any benifits other than looks by running bent links in front? any pros or cons, suggestions welcome |
02-21-2008, 11:14 PM | #2 |
Pebble Pounder Join Date: Jan 2008 Location: Rancho Cucamonga
02-21-2008, 11:25 PM | #3 |
Quarry Creeper Join Date: Dec 2007 Location: At the Gates
i wouldnt really worry about bending them (theyre already bent) |
02-21-2008, 11:28 PM | #4 |
Rock Crawler Join Date: Dec 2005 Location: North Vancouver
I run my stock links bent front and rear. I've put them through hell, I jump it, sheered three rod ends with them and they are still bent the same amount. As mentioned the bought bent links seem to bend easy. Get yourself two sets of pliers mark about an inch inwards, put the pliers on either side and bend. Repeat 3 times to match the bends and you have bent links and it didn't cost you anything. Sure they'll be 2mm shorter but really...are you going to know? I'm all for bent links up front. The advantage is that you have more clearance cresting a ledge so you front tires plant instead of hitting your links. I don't see any cons to running them. My .02 |
02-21-2008, 11:31 PM | #5 |
i noticed that they are longer when i had front and back on, the wheel base was 12 3/4" with the crck heavy duty bent links
02-21-2008, 11:51 PM | #6 |
nicely put, Miller |
02-22-2008, 05:47 AM | #7 |
Quarry Creeper Join Date: Nov 2007 Location: in the shop, of corse!
| yep!
getting up on a ledge or shelf..makes transition much smoother.. droping off.. the same ..kinda gets ya goin the right direction... lets the tires reach down further..this is one of those times where a picture would say a thousand words... MILLER gets it^^^^^^^^^^^ |
02-23-2008, 09:45 AM | #8 |
Quarry Creeper Join Date: Aug 2007 Location: United States
I agree the bent links help with the breakover angle. My truck gets hung up a lot less with the bents in the front.
