02-22-2008, 07:34 PM | #1 |
Quarry Creeper Join Date: Feb 2008 Location: mt sterling
| Bad glitching on the EDGE chassis
Tried very thing I can do.Am using the novak crawler ed. esc,novak 55t motor,MX3 transmitter and reciever.Anyone got any thought I can tryok here's what I have done since last night I have tried 2 different radio and still glitching I moved receiver away from all electronic esc,batteries and motor all moved to front and reiceiver to the back.By the way Novak has already reprogramed the rooster crawler once.
02-22-2008, 07:36 PM | #2 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
Take the crawler rooster esc out. Place in an envelope. Address it to Novac and get it fixed.
02-22-2008, 07:40 PM | #3 |
Pebble Pounder Join Date: Dec 2007 Location: Lexington, KY
Mike, take it by the shop tommorow. Hopefully Steve can get something worked out for you.........It may be the crystals in the radio.
02-22-2008, 07:42 PM | #4 |
Quarry Creeper Join Date: Feb 2008 Location: Rhode Island
Its not the Edge. Its your Crawler Rooster. Novak had a problem with I would want to say over 1/2 of them. It has to do with the radio you have. They will gladly fix it for you, personally I sold mine. I didnt feel like dealing with it, so I got something better. However if you want to keep it, you have to send it to novak to get the software on it updated. |
02-22-2008, 08:02 PM | #5 |
He has allready had it updated. Radio is new as well.
02-22-2008, 08:15 PM | #6 |
Rock Stacker Join Date: Jan 2008 Location: kirby tx
check to make sure the antenna wire is not near the metal of the chassis, i know that will cause glitching. |
02-23-2008, 09:37 AM | #7 |
Quarry Creeper Join Date: Aug 2007 Location: United States
From my expirence the radio system is normally what causes the glitching.
02-23-2008, 01:01 PM | #8 |
Pebble Pounder Join Date: Jan 2006 Location: NEPA
Did you install capacitors on the motor? I once had a horrible glitching problem and it turned out the motor didn't have caps on it. Once installed the glitching went away.
02-23-2008, 03:00 PM | #9 |
Rock Crawler Join Date: Sep 2007 Location: 42N 88.02W
Many things can cause glitching, radio interference i.e. antennae touching metal or motor wires, voltage drop associated with BEC problem or low voltage etc, does glitching occur at a certain time, or sporadically? Got pics or details of your rig?
