02-25-2008, 12:00 PM | #1 |
Pebble Pounder Join Date: Dec 2007 Location: York, PA
| Pinion installs that way? Really?
Maybe I was drinking too much last night, but I believe the instructions for installing the pinion seem wrong? Is it supposed to go in that direction? It looks like the set screw would interfere with the spur. Anybody have a close up pic? I was setting mine up last and thought I was going nuts /me scratches head |
02-25-2008, 12:14 PM | #2 |
That's the way it goes........
02-25-2008, 03:51 PM | #3 |
Pebble Pounder Join Date: Feb 2008 Location: Reno
The picture in the directions has it backwards. The set screw should be against the motor, not at the end of the shaft. I ran into the same problem when I installed my motor. I got it mounted up just like the picture but the wheels would not turn. Fliped the pinion around and everything worked. |
03-06-2008, 08:03 AM | #4 |
Quarry Creeper Join Date: Jun 2007 Location: Calgary, Alberta
It goes whichever way works the best for whatever motor you have. Thats the way it goes.
03-06-2008, 09:06 AM | #5 |
Quarry Creeper Join Date: Apr 2005 Location: South Jersey (Cherry Hill area)
I've use it in both directions and both ways worked fine... setscrew to the outside is an old racers trick to remove the pinion without moving the motor. so theres no wrong or right its whatever works for your setup
03-06-2008, 09:22 AM | #6 |
RCC Addict Join Date: Dec 2007 Location: (LES) Manhattan, New York
True...the instructions say to install with setscrew away from the motor. Although this worked for me..there were a few instances in which i could hear a faint ticking from the setscrew slightly hitting the spur gear. I did however reverse the pinion so that the setscrew is closest to the motor. It makes if harder to get to the setscrew but this eliminated the tick. Now im climbing everything in the apartment...cant wait for my buddy to get his so we can hit some real rocks. I know my girl will be happy since i'll stop making obstacle courses out of laundry, boxes, sofa cushions and shoes. Wow this urban crawling is crazy!!! |
