12-04-2009, 07:01 PM | #81 |
Newbie Join Date: Dec 2009 Location: new york
I accept with information: There is about 1/16" between the two. Stock being an 87t spur,I doubt it'd take much smaller spur to clear the Maxx yokes. ______________________ Taux calculette pret immobilier | Calcul emprunt pret immo | Taux interet calculette credit immobilier |
12-04-2009, 07:56 PM | #82 |
12-04-2009, 11:53 PM | #83 | |
Alternatively, you can chuck it up in a drill and "machine" it down with a file. | |
12-05-2009, 01:46 AM | #84 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
This should be a sticky. |
12-05-2009, 12:15 PM | #85 |
Quarry Creeper Join Date: Mar 2009 Location: !ROX BOX!
I agree Sticky
12-08-2009, 10:13 AM | #86 |
Quarry Creeper Join Date: Aug 2009 Location: Philadelphia, PA
My rear shaft just broke yesterday, will be replacing it with this solution. Thanks |
12-15-2009, 10:04 AM | #87 |
I just got around to replacing the broken shaft. The unibit/stepper drill bit worked great, instead of using a 29/64 bit I used 7/16 for a closer fit. I used a sears handi cutter to cut the shafts. The male was first and I used the cut off part and stuck it into the female so when it was cut it would not crush or deform. I also boiled the assembled shaft to relieve stress (for about 15 minutes). I used 4 6mm long button head screws for attaching it to the shafts, i still have to grind the yoke a little to clear the 87 spur.
02-24-2010, 08:42 PM | #88 | |
Quarry Creeper Join Date: Nov 2008 Location: Lightin' The Desert In
what if you wanna go from a maxx output to a axial output? trying to adapt intregy HD driveshafts to a emaxx tranny, an cant figure out hot to get theshaft to mount to the tanny with no slop, possible way to adapt a emaxx output to axial output? | |
02-24-2010, 09:56 PM | #89 |
| Drill the Integy yokes out to 6mm and use the Traxxas thru-bolt?
03-17-2010, 08:32 AM | #90 | |
I wanna be Dave Join Date: Aug 2008 Location: Austin, TX, USA
But I have to say ordering up some Wheelie King yokes with a 6mm input and putting those into my Axial axles looks to be a nice way to go, too! | |
03-17-2010, 10:01 AM | #91 |
Quarry Creeper Join Date: Jun 2008 Location: Lapeer
Great write up Jason' and thank's for sharing it with us too'
04-01-2010, 07:22 AM | #92 | |
04-01-2010, 10:28 AM | #93 |
Well, I just ordered some Punisher shafts anyway. Didn't have the patience (or the proper tools) to drill out the yokes. |
09-24-2010, 06:01 PM | #94 |
Rock Crawler Join Date: Feb 2004 Location: Astoria, Oregon
Anyone with a lathe willing to drill out some maxx yokes for a fee?
12-10-2010, 05:20 PM | #95 |
I wanna be Dave Join Date: Mar 2004 Location: The Haunted Forest
None of this is necessary if you stick with MIP C-drives. 6mm to 5mm or vice versa is easy! http://www3.towerhobbies.com/cgi-bin...&I=LXUUA9&P=ML + http://www3.towerhobbies.com/cgi-bin...?&I=LXXDM4&P=7 = Win. |
12-28-2010, 03:36 PM | #96 |
Newbie Join Date: Dec 2010 Location: Rathdrum
| win -$50 bucks
07-08-2011, 06:51 PM | #97 |
Newbie Join Date: May 2011 Location: Ocala
After about 3 broken yolks I decided to buy some new drive shafts until I saw this thread. I dug around in my parts bucket and found some old tmaxx shafts and did this mod in about an hour. Best part of it, it was FREE. Thanks for the right up.
07-09-2011, 01:32 PM | #98 |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
08-04-2011, 04:55 PM | #99 |
I joined the Band! Join Date: Mar 2010 Location: nashville,TN
ok drill press does not work! i just ruined 3.
08-04-2011, 05:10 PM | #100 |
Quarry Creeper Join Date: Mar 2010 Location: murrieta
