03-14-2008, 01:36 PM | #41 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
Looks good. Why did you decide to use the slipper? I know you are familar with using slippers, but do you think the ax10 tranny really needs it?
03-14-2008, 01:48 PM | #42 | |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
I've been running an AX10 tranny for a few months now, and it's held up fine to my abuse. But, the slipper clutch can help prevent breakage in binds, especially if you run brushless. And it can be adjusted to slip when you want it too. | |
03-14-2008, 03:29 PM | #43 |
RCC Addict Join Date: Aug 2007 Location: Toronto, Canada
Awesome start to the build up there Fred.. (Brad) Your build threads are always nice to use as a reference. Easy to follow, pictures are always clear and in focus. Got a lid picked out yet? |
03-14-2008, 03:37 PM | #44 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
I know what is missing..... VF Dig! Check out the big build from Brad! I am having tool envy. Need to get a set. |
03-14-2008, 04:44 PM | #45 | ||
The VF dig is in the plans too. | ||
03-14-2008, 04:49 PM | #46 |
TEAM RCC Join Date: Oct 2005 Location: THE ALIEN WORKSHOP
Looks good Brad It won't be long until I make the swap too.
03-14-2008, 05:51 PM | #47 |
| Thanks Scott. I have a feeling I'll be working on my rig a lot less once I make the switch from TLT axles. I got the slipper installed on the tranny. Look for an article on the front page of RCC for all the details. Last edited by BENDER; 03-15-2008 at 11:43 PM. |
03-14-2008, 05:54 PM | #48 |
Quarry Creeper Join Date: Dec 2006 Location: Corbin KY
are those the stock output shafts? the rear one looks different.
03-14-2008, 05:59 PM | #49 |
03-14-2008, 06:04 PM | #50 |
RCC Addict Join Date: May 2006 Location: USA
bender why would you ever build a comp rig without the RCP Max Clearance knuckles? they are a MUST HAVE for any comp rig: http://www.rcpcrawlers.com/product.p...&cat=29&page=1 |
03-14-2008, 06:06 PM | #51 | |
03-14-2008, 06:08 PM | #52 |
03-14-2008, 06:13 PM | #53 |
03-14-2008, 06:26 PM | #54 |
Rock Stacker Join Date: Dec 2007 Location: Morristown
I like them rims how much did they run you.
03-14-2008, 06:38 PM | #55 |
| Thanks, the wheels are $99 a set. http://www.montanascaledesigns.com/s...products_id=29 |
03-14-2008, 06:58 PM | #56 |
I wanna be Dave Join Date: Sep 2005 Location: R.I.P. Chip
Lookin' good man! Those wheels are the best fo sho! I picked up a set of axles too. |
03-14-2008, 07:40 PM | #57 |
I wanna be Dave Join Date: Jan 2004
Man! If this thing had some Proline Hammer tires on it, it would be unstoppable!!!!!! |
03-14-2008, 10:58 PM | #58 |
Do you think a slightly longer shock is needed when running the AX-10 axles w/ their lower mounting points compared to the TLTs? Seems like another 10mm in length is necessary to maintain the same center chassis height as a TLT based rig?
03-14-2008, 11:10 PM | #59 | |||
I have the longest Losi truck shocks available on my TLT. They are probably about 10mm longer then standard 4" shocks. I'll swap them over to this build if I decide I need more clearance. | |||
03-15-2008, 09:09 AM | #60 |
RCC Addict Join Date: Mar 2005 Location: DODGING ROCK CHUCKERS
I thought I was going to have to go with a longer shock on my SW3, but so far I like it much better with a 2.75" belly clearance. Cant wait to see this thing done Brad, so get wrenchin |
