07-07-2009, 08:57 PM | #921 | |
Pebble Pounder Join Date: Apr 2009 Location: Crawlerado Springs
Hey Bender do you have any Pics of your Chassis? How did you get the servo to fit with the supplied servo mount and the SWX chassis? Thanks | |
07-21-2009, 09:05 AM | #922 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
Bender, how is the VP dig working out. When you have time please post some pics of the dig setup, thanks.
07-21-2009, 09:18 AM | #923 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
The VP dig works awesome. I ran it this past weekend at the Red Rocks comp in Colorado and it worked flawlessly for me. My transmission mounting point is a little different from stock. So, I'll try to get my set-up bolted into a stock SWX chassis and post some pics for everyone this week. |
07-21-2009, 09:28 AM | #924 |
"HOLLYWOOD" Join Date: Dec 2008 Location: Miami
Beside the upgrade of your DIG any other new tips added? By the way if your looking for a roommate in your location let me know "Signing Boobs" sounds like a killer place to live lolololol |
07-21-2009, 10:31 PM | #925 | |
RCC Addict Join Date: Nov 2008 Location: Frederick
What do you mean by change your trany mont post? This is what I did to get my VP in. Had to make some change's to get it there but, It worked out good. God damm I love this dig! | |
07-22-2009, 07:32 AM | #926 |
What mods did you have to do?
07-22-2009, 10:10 AM | #927 |
Looks to me like your rear upper link hits the dig servo VP is going to make a mount for a mini servo, which might give more clearance.
07-22-2009, 10:27 AM | #928 |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
God the SWX's are sweet man. i love this chassis. now with both the DNA and VP digs available, we gots good options. im actually debating getting a micro servo, due to the fact i broke the mounting brackets on my current dig servo. its held in by faith and ghetto rigging right now. i think id try and mount it low on the chassis itself, or fab up a new lil bracket. i also recently moved my uppers to the highest mounting point on the chassies, and it climbs up shit that it couldnt before. the lil bit of additional squat really works well w/ my COG. |
07-22-2009, 11:16 AM | #929 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
| He is not using the standard setup. It is a deviated version of what everyone else gets. |
07-22-2009, 05:35 PM | #930 | ||
| I only had to move the esc,rx,bec around for it to fit. Quote:
At frist I moved my uppers down to clear the servo and also lost a lot of climbing. That is why I flipped the srew head on the inside. It dose not seem to both the the digs movement. I got to see this. Pics please. | ||
07-23-2009, 07:44 AM | #931 |
I wanna be Dave Join Date: Dec 2008 Location: ?
Bender I see that all other dig's the drive shaft have to be shorten. With this new Vanquish dig do I still have to shorten the drive shafts? Also what turn motor do you run and what is your gearing Last edited by sally1800; 07-23-2009 at 08:40 AM. |
07-23-2009, 09:26 AM | #932 | |||
Thanks for the compliments on the chassis guys, glad you like it. Quote:
You'll have to shorten the driveshafts a little. The driveshaft doesn't move when using the VP dig, but you are lengthening the tranny when you bolt the unit up. | |||
07-30-2009, 11:46 AM | #933 |
bender I see you run losi red in front and one rear and silver in the other I have mod big bore shocks the spring you are running will be short for me right. what do you feel will work best with big bore? Have you ever used traxxas progressive spring? |
07-31-2009, 09:25 AM | #934 |
| I think my old Losi springs will be too short to use with the big bores. I've never run big bores so I'm not sure what springs would work best. I've never tried the progressive springs either. But, they may work decent. Sorry I couldn't be more help. |
07-31-2009, 10:24 AM | #935 |
Bender do you have any pictures with the new shocks (butter) let's see the goods man Last edited by sally1800; 07-31-2009 at 11:49 AM. |
07-31-2009, 01:29 PM | #936 |
Liking the new sig |
08-03-2009, 08:51 AM | #937 |
Bender show the goods man |
08-06-2009, 01:59 PM | #938 |
Yea let see some new pics with that sick new body and whats packing under the hood? How are you liking the new axial shocks compared to the losi's you were running befor? |
08-16-2009, 01:35 AM | #939 |
Pebble Pounder Join Date: Jun 2009 Location: Finland
Looking good bender . What kind of foam you use? Have you cut it?
08-22-2009, 08:49 PM | #940 |
Quarry Creeper Join Date: Apr 2009 Location: Ukiah
For everyone who runs this chassis what is your wheelbase at? Belly clearance? I'm puttin mine together and having one hell of a time. My WB comes out to 12 3/4" and belly at 3". I'm using the "phatty" delrin links. When I first put it together my axels were clocked in pointing my axel outpout towards the ground. I put spacers in the upper links to force the axels to clock out so the output is facing up. Now the clock is correct but WB is to long.:? I can post pics of this if it would make more sense. |
