Thread: New Comp Build.......SWX......New Production Pics!!
Old 04-01-2010, 08:40 AM   #1001
2006 2.2 National Champ
BENDER's Avatar
Originally Posted by Mini View Post
Looks like you 4 sure got more angel steer thats 4 sure....
That last pic at the comp looked a little scary...... Looks like a looooooooooooooooooooooooooooooong drop.
It was a long drop, but very driveable.
Originally Posted by C_Money View Post
Next question, what do you like for a motor turn? And gearing? Probly depends on the course but generally what do you run? Thanks
I run a 45t motor with stock gearing and a 3s lipo. Good wheelspeed, and decent torque.
Originally Posted by SDheavymetal View Post
Have you had any problems with the bearing slipping in the plastic axle? Some guy use red lock tight. Are you going to remove the turn stops?
I haven't driven it yet. But, I did use blue loc-tite on the outer bearings. We will see if it holds them in place. I have a prototype BTA tierod, and the stops aren't in the way at all.
BENDER is offline   Reply With Quote
Old 04-01-2010, 10:32 AM   #1002
nice rig
yellowv22 is offline   Reply With Quote
Old 04-01-2010, 06:14 PM   #1003
sim
Originally Posted by BENDER View Post
Got the ring gear machined out for the new bigger shafts. Chucked up the ring gear in our lathe and bored it out with a 1/4" carbide end mill.
Brad,
I know you said 1/4" carbide end mill, but the pic you posted looks a bit like a twist drill bit. Is there an extra step to it or is it just my eyes playing tricks on me? I just want to make sure and do it the way you did it, when I get mine. Thanks.
Edit: Nevermind, it was just my eyes. Just noticed all the tiny chips.
sim is offline   Reply With Quote
Old 04-01-2010, 10:32 PM   #1004
Most places you go do you not change your gearing or motor? Just curious and also what are the specs of the battery you use? Just getting an idea of what type it takes to complete a comp.
C_Money is offline   Reply With Quote
Old 04-02-2010, 12:43 PM   #1005
BENDER's Avatar
I don't change my gearing or motor for the most part. Try to find a set-up that has decent wheel speed and torque. I run 1100mah 3s lipos from MaxAmps. They are compact and have good punch.
Old 04-05-2010, 07:35 PM   #1006
What shock oil have you found works best at most places?
Old 04-06-2010, 08:53 AM   #1007
BENDER's Avatar
I run 15-20wt out front with really soft springs. Out back I run 35wt oil the the right rear with the same springs as the front. Then I run 50wt oil in the left rear with a little stiffer spring rate.
Old 04-08-2010, 05:27 AM   #1008
Location: You will never find a more wretched hive of scum and villainy
not to thread jack or anything but...
i got a set of axial alum C's and when installed i have a bad bind. so i changed my super 300's out and put the stock axial shafts back in, again the bind. i put the plastics C's on and no bind. are you having any issues with your 300 build ?
DeweyCJ5 is offline   Reply With Quote
Old 04-08-2010, 09:06 AM   #1009
BENDER's Avatar
Weird. I haven't had any binding at all in my set-up. Makes me wonder if there is an issue with that particular set of C's. You can try calling customer service and see if they have heard of any issues, 949-600-8642.
Old 04-08-2010, 11:12 AM   #1010
thanks
Old 04-30-2010, 10:48 AM   #1011
You mentioned on the axial blog that you reduced you front wheel weight.
What is you current all up wheel weight in the front, and rear?
redxz30 is offline   Reply With Quote
Old 04-30-2010, 10:52 AM   #1012
BENDER's Avatar
I did reduce my weight recently. My front wheels weigh in at 13 ounces each now, my rears weigh about 10 ounces each.
Old 04-30-2010, 10:56 AM   #1013
Just ordered a SWX from the local hobby shop. Can't wait to get tuning on it. I'm trying to get my Big Bores setup right now. Just trying to find a good 4 link BTA kit now to get some better steeriing.
doors4u is offline   Reply With Quote
Old 08-13-2010, 12:32 PM   #1014
Default Lower Links- Delrin
I went through the entire 51 pages of this thread and noticed that you are still running the Delrin lower links, where can you get these links? Or did you make them? Great build, I am new to the sport but this was an inspirational review of your build, now I have something to shot for.
Thanks
-DMS
Turboman is offline   Reply With Quote
Old 08-13-2010, 03:41 PM   #1015
i just got my SWX 2 days ago..
just finished assembling everything from my AX10 to the SWX.
kindly suggest me the suitable suspension (and spring) that best suit the SWX chassis.
TQ
VR6T is offline   Reply With Quote
Old 08-14-2010, 08:23 PM   #1016
http://www.axialracing.com/details.php?Id=3942
Creepy Inc. is offline   Reply With Quote
Old 08-16-2010, 09:46 PM   #1017
Hey Brad i saw that you said your front track width is 10.5, Is it still the same with the Super 300's? Right now I'm barely 10 and I want to get to at least 10.25 but I'm not sure how to with the Super 300's.
Thanks, Allen
Old 08-16-2010, 11:01 PM   #1018
BENDER's Avatar
Thanks
-DMS
Thanks for the compliments Turboman. I did make the Delrin links myself. You might be able to find a vendor here that would make Delrin lowers for you though.
TQ
I run Axial red springs up front and on the right rear with 20-30wt oil. In the left rear I run a little stiffer spring and oil to help fight torque twist.
Thanks, Allen
It is still the same width. I am running some old TLT CVD hexes with barrel nuts out front, they give me the extra 1/2" of width.
Old 08-17-2010, 01:11 AM   #1019
TSK
Shelf queen
TSK's Avatar
He said four link. Check out the LD kit in the vendors section
TSK is offline   Reply With Quote
Old 08-17-2010, 03:29 PM   #1020
Humm, I'm going to have to look in to that. Were did you get the barrel nut if you don't mind me asking? I take it there MIP hexes or Tamiya?
My bad
