03-20-2008, 09:58 AM | #121 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
So you didn't have enough room for a servo horn for the drag link where the servo was mounted before? to close together. :-(
03-20-2008, 11:52 AM | #122 | ||
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Yeah, I like your speed holes too. Correct. I could have moved the tie rod down under the knuckles and there probably would have been enough room. But, I want to keep the tie rod on top of the knuckles so I had to move the servo up a little. | ||
03-20-2008, 12:07 PM | #123 |
RCC Addict Join Date: Feb 2007 Location: Chucking rocks at your little truck!
Looking good Brad. Cool servo mount too. When are you gonna kick start it and crush some rocks? Or will you just run it on the oval instead? O.I.F.F. |
03-20-2008, 12:14 PM | #124 | |
This rig would dominate the oval. | |
03-20-2008, 12:17 PM | #125 |
Brad, what driveshafts are you going to use? |
03-20-2008, 12:20 PM | #126 |
03-20-2008, 12:26 PM | #127 |
I can't beleive I missed that thread. I was wondering how you where using maxx shafts. Exceellent idea, I will have to try that mod. |
03-20-2008, 05:15 PM | #128 |
| That is a nifty idea, and it also reinforces the upper linkmount. |
03-20-2008, 09:12 PM | #129 |
Rock Crawler Join Date: Apr 2007 Location: APPLE VALLEY,CALIFORNIA
Great build...thanks Brad for your great informative build threads ...always very detailed...one question ,just curious why you decided to stay with the 3 link as opposed to the 4 link ?? would like to hear your thoughts of 3 vs. 4 link set ups...thanks again
03-20-2008, 11:43 PM | #130 | |
| Thanks, it cleans up the rear axle and supports the upper link mount nicely. Jason was the first to mod his rear plate, that I've seen. Quote:
I'll probably be messing around with a 4 link set-up at some point too. I've built a few of these SW3 AX10 rigs though, and the stock upper 3 link has worked great so far. Plus it gives you more room on the top of the axle to mount servos and batteries. | |
03-20-2008, 11:48 PM | #131 |
Quarry Creeper Join Date: Dec 2007 Location: At the Gates
03-20-2008, 11:57 PM | #132 |
| How are you holding the battery to the upper links? It doesn't bind the suspension? You're better off with a 3 link, because the upper link doesn't twist, it just moves up and down. My upper links sits flat right now, and the battery will be mounted on the front axle too. |
03-21-2008, 12:07 AM | #133 | |
03-21-2008, 12:11 AM | #134 |
Hey Brad, do you know anything about 4-links |
03-21-2008, 12:15 AM | #135 |
03-21-2008, 12:20 AM | #136 |
| Im not trying to talk trash, im just sharing my thoughts. perhaps i will keep them to myself. I bow down to you.... master.. |
03-21-2008, 12:38 AM | #137 |
03-21-2008, 01:06 AM | #138 |
03-21-2008, 01:33 AM | #139 |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
Have you ever seen a real crawler?
03-21-2008, 01:47 AM | #140 |
