Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: battery plate
Old 03-13-2008, 07:31 PM   #1
Default battery plate
I made a new battery plate tell me what you think
spyderzombie is offline   Reply With Quote
Old 03-13-2008, 07:47 PM   #2
Looks good, although I would maybe try and mount the batteries lower just for CG's sake. Also it looks like your C's are switched around giving your steering links a weird angle.
dc2drifterx is offline   Reply With Quote
Old 03-13-2008, 07:55 PM   #3
Damn-I need a chump RT!!!
yotachump's Avatar
if your battery's are going to sit on your servo that is to high
yotachump is offline   Reply With Quote
Old 03-14-2008, 07:35 AM   #4
Radius dem corners mane.
That might be a tad on the high side. What kind of pack are you putting up there?
BigRocks is offline   Reply With Quote
Old 03-14-2008, 10:36 PM   #5
Im puting 2/3 size batt onder servos and size c on the top
