Thread: Mirror Imaged Transmission
Old 07-13-2008, 03:36 PM   #41
I'm probably the only one to have screwed this up, but after I did it when I went "forward" on my radio, the truck would go backwards. I reversed the throttle via the transmitter and now it goes faster in reverse and I have to tap twice to get it to go forward, what the heck did I do wrong?
thelmuffinman32 is offline   Reply With Quote
Old 07-13-2008, 04:28 PM   #42
Can you take a pic? It sounds like you flipped the motor backwards with the tranny. A buddy of mine did that after I tried to explain the mirror flip on the phone. He actually ended up with the motor on the opposite side but turned around too. (Not a mirror flip). If you want to leave it, I guess you could reverse your wires and put your radio back to normal. Then the only thing going backwards is your motor... and it doesn't really care.
If that is not what happened.. then Idunno....
Harvo is offline   Reply With Quote
Old 07-14-2008, 09:39 AM   #43
Got you guys some pics to help me out:
Thanks alot for all your guys's help!
P.s. Excuse the wiring, it's only temporarily messy.
Old 07-14-2008, 10:11 AM   #44
Shoot! Just move your steering gear to the other axle and you're set! (Always thinking outside the box!)
Or you can go the convential way and just rotate ur tranny 180*. You did the mirror correctly, you just got the tranny in backwards.
cpd438 is offline   Reply With Quote
Old 07-14-2008, 10:18 AM   #45
Custom Carbon Fiber
Robbob's Avatar
You need to reverse the WIRES on your motor, not your radio settings.
OR
flip your belly tray around and mount the tranny with the spur to the BACK and leave your motor wired normally.
crappy picture but should give the idea. with it this way the motor is wired normally ( red + black - )
[IMG][/IMG]
Robbob is offline   Reply With Quote
Old 07-14-2008, 10:31 AM   #46
I'll just flip the tray/tranny mount thing around 180*, thanks alot guys!
Old 07-14-2008, 11:12 AM   #47
WOW, it drives MUCH better! Not trying to thread jack, but do you guys have any other tips for lowering the cog on this thing?
Old 07-18-2008, 11:38 AM   #48
I must add that this mod is awesome! I was only able to drive it for a few minutes due to messed up yolks (long story), but I could tell that the weight transfer was alot smoother, maybe even non-existent.
thanks a bunch EeePee!!
helhedded is offline   Reply With Quote
Old 07-26-2008, 08:06 PM   #49
I just did this mod and it helped a lot with torque twist. Thanks!
mulepic is offline   Reply With Quote
Old 07-27-2008, 08:31 AM   #50
MODERATOR™
EeePee's Avatar
Well that's good to hear guys, glad it's working out for yas.
I'm building me another AX10 and took a couple shots of the mirrored tranny mounted on a TCS skid, with the CDW 6mm outputs, and with the baddest motor out there.
EeePee is offline   Reply With Quote
Old 07-27-2008, 09:24 AM   #51
What's the plan for this one? I figured after you built your cheater truck, you wouldn't mess with these anymore...
Old 07-27-2008, 02:32 PM   #52
MODERATOR™
EeePee's Avatar
Well you're right, as far as comps go, and being serious, it's all about the cheaters. But as far as having fun goes, shafts are the shit. I'll show and tell later when I'm further along.
Old 07-27-2008, 03:25 PM   #53
Default mirror tranny
You may hate me for this but..
Building my first crawler ARTR Ax-10, seasoned Rc'er who can't leave anything stock. Already torn the truck apart and fabbing 4 link plates/battery holder w/ servo mount. While I have the tranny out I was thinking of doing this mod. I hope I understand the torque twist tries to lift the passenger tire up in driving? So putting the motor up front helps the weight and makes the rotating work in favor of keepin that side down?
When doing the mod just have to be sure motor rotates the right direction. One last question.... I'm running the Rooster(crawler) 55t novak motor will these accept this direction change?
Joiner is offline   Reply With Quote
Old 07-27-2008, 04:09 PM   #54
MODERATOR™
EeePee's Avatar
Right. More about the weight I'd say than rotating though. The driveshaft/pinion gear is still trying to climb the ring gear.
There is no direction change. The motor is still rotating the spur gear the same direction, but from the other side, not the driver's side, but the passenger's side.
Old 07-27-2008, 05:01 PM   #55
Default Tranny rev
Just did this mod. In a matter of days this will become standard on all rigs. Thanks for your help and pateince. Sticky this now!!
Old 07-27-2008, 08:39 PM   #56
MODERATOR™
EeePee's Avatar
I started the thread in March.
Old 07-27-2008, 09:24 PM   #57
I love how a noob can bring a half year old thread back to life all by himself
R2D tranny OWNS
Jeepernick is offline   Reply With Quote
Old 07-28-2008, 04:37 AM   #58
MODERATOR™
EeePee's Avatar
Originally Posted by Jeepernick View Post
R2D tranny OWNS
Try, Bergs own.
Old 07-28-2008, 08:45 AM   #59
Originally Posted by EeePee View Post
Try, Bergs own.
Nah I like giving Bergs the shaft still..................... not taking it
I have only seen one berg in real life and it was sitting on a glass top and never seen one on the rocks.... so I dont really know what they can do
Ive seen the videos and im sure they are all like Hollywooded out, cut and edit bigger rocks in and such
plus berg axles are $$$$
Old 08-04-2008, 04:40 PM   #60
Since torque twist is such a big issue, why would the maufacturers build the tranny that way? Why not build it mirrored and market it as a better crawling setup??
raceplus is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-ax-10-scorpion/110323-mirror-imaged-transmission.html
Posted By For Type Date
Scx10 Tr - THE SCALE BUILDER'S GUILD - Presented by JOWETT'S KUSTOM RC This thread Refback 10-04-2011 07:30 PM
