12-20-2008, 04:10 AM | #81 |
RCC Addict Join Date: Apr 2008 Location: Sacramento
Question for you, if I wanted to add a DNA dig setup will it work in this configuration or will I have to turn the motor and transmission around?
12-20-2008, 09:56 PM | #82 |
For the DNA dig unit to work, you need to have a stock transmission.
12-20-2008, 10:37 PM | #83 |
if your looking to keep the mirrored tranny and install a DIG unit you can do this with one modification to the CKRC unit. if you look in my CDW build for my 2.2 comp rig there are pictures showing what I did to accomplish this. DNA DIG is a great unit but I prefer the mirror tranny and have been very pleased with the CKRC unit attached to it. |
12-21-2008, 08:22 PM | #84 |
Newbie Join Date: Jan 2008 Location: Central Coast
Alphadog Same as others have done. If Im reading picture correct, front of rig is to the left in pic, (Unless youve got rear steer) Youve got motor & tranny in 180 backwards. Spur gear should be in back...puts the motor on right (passenger) side of rig Are those snow chains??? Mark |
12-24-2008, 03:57 PM | #85 | |
RCC Addict Join Date: Jan 2007 Location: San Jose
Do you think of any other possible way for it to work? thanks for your help! | |
12-24-2008, 03:58 PM | #86 | |
Can the same mod that you have done be done with dna dig? thanks! | |
12-25-2008, 07:52 AM | #87 |
12-25-2008, 03:15 PM | #88 | |
Well, I am not even sure if putting the motor to front and on pass side even really made that much of a diff. I wonder if you can make a case that is flipped? well, thanks for the input. | |
02-05-2009, 02:01 PM | #89 |
Pebble Pounder Join Date: Dec 2008 Location: uhh,,, i forgot
i tried the hot racing dig and it works, the only thing is you have to flip the transmission bolts and invert everything
02-05-2009, 02:40 PM | #90 |
Rock Stacker Join Date: Dec 2006 Location: eaton
will be doing this to my new rig as soon as it gets here
02-05-2009, 10:42 PM | #91 |
Newbie Join Date: Dec 2008 Location: on planet earth
Gromitt327 is right. With the vf dig you have to flip the tranny so the motor is on the right side.you could reverse the skid though so the spur is in the back and dig and motor is up front.
03-07-2009, 09:16 PM | #92 |
Newbie Join Date: Oct 2004 Location: Albuquerque
I tried the mirror tranny and ended up with torque twist. I am running a Novak Goat setup and it gave me a lot of torque twist. Before I tried this, I had turned the tranny plate around so the gear is facing the front of the rig. That got rid of almost all the torque twist but I thought I would try this. It made it like it was before I turned the gears to the front. I changed it all back and now it works like it did before which was great. I am not sure but I know this motor has a lot of torque and when it spins the way it is set up to spin in normal rotation, it helps raise the right front wheel off the ground. By turning the tranny around, I have to reverse the motor rotation at the speed control and it torques the chassis the opposite way down to the ground instead of trying to lift it up. This may not work for anyone else because of the way my chassis is set up but it does work for me. The mirror tranny idea is a great idea and I am sure it works for a lot of people. Just thought I would throw in my two cents worth.
03-08-2009, 08:10 AM | #93 |
Rock Crawler Join Date: Mar 2004 Location: Where it's wet
I just saw this thread. You just made my weekend Ep Now the bigass spur will be up under the dash 8-)
03-08-2009, 01:36 PM | #94 |
11-16-2009, 12:28 AM | #95 |
Newbie Join Date: Oct 2009 Location: Delta B.C.
Well i did the mirror trans mod tonight it took 15mins or so the big sprocket stayed to the rear and the motor is now on the passenger side. it made it so my passenger side tire stays on the ground when i launch it now, when before it would lift about two inches but would drop quickly. Before that i did the four link over under on the rear only the passenger wheel would stay up for a bunch longer so that helped first. So the combo of both really has helped me out. My lower and upper links are quite parallel to the ground. with exception to the passenger side upper rear which is on a slight incline towards the trans plate on account of it being bolted under the 4 link plate. I figure the weight of the motor and the fact that the drive shaft is is now on the drivers side made the biggest difference. think of the torque as a ratchet, before the ratchet had a long handle, easy to torque on stuff. Now with the drive shafts on the other side it seams like a short handle ratchet, harder to turn to get the same amount of torque. Inch/pounds. makes sense to me. I have internal springs all the same size at "1.5/16th under the piston and nun above. I have over 1/2 droop that is now my rebound. Not finished yet still have the battery on top that will move when i can get the Behind the axle set up from Axial. All in all i found the Trany mod worked for me to really help keep my front planted under heavy throttle. Thanks allot EeePee This stuff is fun Mike |
12-18-2009, 10:35 AM | #96 |
Rock Stacker Join Date: Oct 2009 Location: Phoenix
Did the mirror trans mod too,,,thanks for the tip,,,works a bit better now. Definetly does not raise the front left wheel nearly as much when you peg the throttle from a dead stop.
12-18-2009, 10:46 AM | #97 |
Rock Stacker Join Date: Aug 2004 Location: Under a Rock
Now does the trans have a bearing on both ends of the the spur gear shaft ? When I took mine apart "ARTR" to do this it had the alum spacer and a plastic spacer/bushing.... Been thinking I did something wrong or misplaced it ! |
12-18-2009, 10:49 AM | #98 |
| Yes, in the trans,, u have to open it up and make the output shaft go in the opposite direction. Then just move the plug to the other side.
12-18-2009, 10:50 AM | #99 |
i have tried both the mirror image tranny and turning my tranny around 180 degrees where the spur gear faces the front of the truck. for me turning the tranny around worked tons better than the mirror image. i have to get in a real bind to get the tire to lift off the ground and it settles much quicker when climbing over rocks. im not saying its the best way but it worked very well for me. another thing that worked good for me was to locate the battery over the front axle which im sure most are doing. i think the way you have the rest of the vehicle set up is what makes changes either work very good or not work at all. just keep trying and you will find the best setup for you and your vehicle.
12-18-2009, 10:55 AM | #100 | |
Is this right or not ? And if not WTF ? | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-ax-10-scorpion/110323-mirror-imaged-transmission.html | ||||
Scx10 Tr - THE SCALE BUILDER'S GUILD - Presented by JOWETT'S KUSTOM RC | This thread | Refback | 10-04-2011 07:30 PM |
