12-18-2009, 10:56 AM | #101 | |
Rock Stacker Join Date: Oct 2009 Location: Phoenix
12-18-2009, 10:58 AM | #102 |
| U got it,,, that aluminum spacer,, a plastic one, the pin , spur gear. no bearing on the outside of the tran on the shaft
12-18-2009, 11:06 AM | #103 |
Rock Stacker Join Date: Aug 2004 Location: Under a Rock
02-28-2010, 01:09 PM | #104 |
RCC Addict Join Date: Jan 2010 Location: Dallas
| Mirrored and only slightly better
I am getting stupid amounts of torque twist and mirrored my tranny this am. Only slightly better.
02-28-2010, 01:34 PM | #105 |
Well, it's definitely not the end all, cure all modification. Little help here, little help there to do what we can to get these trucks working better. |
03-06-2010, 03:56 AM | #106 |
Newbie Join Date: Feb 2010 Location: oak harbor
03-06-2010, 05:29 AM | #107 |
03-06-2010, 08:32 AM | #108 |
03-06-2010, 08:37 AM | #109 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
03-06-2010, 08:39 AM | #110 |
03-09-2010, 04:27 PM | #111 |
Rock Crawler Join Date: Jan 2010 Location: SOUTH CRAWLINA
Do you need to do this if your going to run a vanquish dig?
03-09-2010, 04:47 PM | #112 |
Hoof Hearted? Join Date: Nov 2009 Location: Chattanooga
05-11-2010, 04:44 PM | #113 |
Pebble Pounder Join Date: Apr 2010 Location: Manitowoc
Hey guys thanks for the info going to have to try that
05-11-2010, 05:19 PM | #114 |
Newbie Join Date: Jun 2009 Location: whitehall
haha i did this on accident!
11-07-2010, 01:46 PM | #115 |
Newbie Join Date: Oct 2010 Location: Menifee, Ca
So what does "mirroring" do? Just because you can do it does help anything? Bob |
11-07-2010, 01:51 PM | #116 | ||
First page has some details, incase you didn't read anything, I'll quote myself. Quote:
01-10-2011, 05:34 PM | #117 |
Newbie Join Date: Dec 2010 Location: Rathdrum
just did the mod, definitely cut down on the forwards torque twist, but the reverse torque twist is crazy, it will lift both tires, with obviously one much more then the other. geuss no more reverse rockcrawling for me |
01-11-2011, 11:01 AM | #118 |
Rock Crawler Join Date: Nov 2010 Location: Ohio
| I had the same problem, I added 1.75oz to each rear wheel and tamed it quite a bit. |
03-24-2011, 10:57 AM | #119 | |
Newbie Join Date: Dec 2010 Location: Gold Canyon
Chris Last edited by snoking; 03-24-2011 at 10:59 AM. | |
03-24-2011, 12:21 PM | #120 |
Still thinking about this. If moving the diff in the front axle would effect the torque on front axle, then moving the output in the chassis to the other side would effect the torque that is to transfered to the classis, thus effecting the rear suppension more than front axle lift, maybe? Guess I will go do the swap and see how it effects the crawler. I kinda want to see what is in the tranny away, as I bought the crawler used. On edit: Tranny was all stock inside and it good shape. Found that my second delrin skid plate was cracked/broken, so I installed an Aluminum one this time. Guess I will have to stop falling off rocks!!! Off to test after lunch. Chris Last edited by snoking; 03-24-2011 at 01:48 PM. |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-ax-10-scorpion/110323-mirror-imaged-transmission.html | ||||
Scx10 Tr - THE SCALE BUILDER'S GUILD - Presented by JOWETT'S KUSTOM RC | This thread | Refback | 10-04-2011 07:30 PM |
