07-11-2012, 04:40 AM | #161 | |
I joined the Band! Join Date: Jul 2011 Location: Philippines
| Re: Mirror Imaged Transmission Quote:
ill give it another shot later today.. but i know i tried that.. it seemed that the cap wouldnt fit on the other end... stay tuned... | |
07-01-2013, 03:12 AM | #162 |
Newbie Join Date: May 2013 Location: Albuquerque
This should fix the way my body flexes. Thanks. Sent from my iPad using Tapatalk HD |
07-27-2013, 02:55 AM | #163 |
Newbie Join Date: Jun 2013 Location: idaho falls
this thread should be sticky link, super simple free mods
12-03-2013, 09:34 PM | #164 |
Rock Stacker Join Date: Feb 2011 Location: British Columbia
I'm looking at many of these shafty builds going on right now and it doesn't seem that any have a mirrored trans. Does anyone do this anymore?
12-04-2013, 07:36 AM | #165 |
Rock Crawler Join Date: Feb 2013 Location: york
We all do if you notice our motors are on the passenger side stock is on the driver side
01-18-2015, 02:16 PM | #166 |
Rock Stacker Join Date: Sep 2005 Location: North Brookfield
i know this is an old post but the pics on the first page helped me out greatly. just got done mirroring my transmission.
01-18-2015, 02:24 PM | #167 |
Not old to me! Thanks for mentioning it. |
01-18-2015, 02:42 PM | #168 |
It's old man but still useful nonetheless. Helped me when I started out. Good to see people searching for information. Surprised to get a notification for this thread. |
01-19-2015, 12:43 PM | #169 |
Newbie Join Date: Jan 2008 Location: Central Coast
Huh-I also was surprised to receive email... Never did this mod as the AX worked OK. Lazy, couldn't justify the effort. However the AX has been setting in a box for almost a year in pieces from the last time I drug out to play. I got the pieces to fix but after setting on the bench for 2 months, moving the parts around I finally packed it up and put in cabinet to clear my bench. This bump has motivated me to gather up the pieces and get running again. As I need to disassemble to fix I could also pick up the mirror mod. Has to help, as mine gets older the wear & slop the lift gets worse. If it doesnt help lift it still probably work better than in pieces |
02-12-2015, 12:15 PM | #170 |
Pebble Pounder Join Date: Apr 2013 Location: Bonney Lake
Just mirrored my tranny on my jk 4 door and it has alleviated almost all torque twist making my rig much more stable. thanks EePee Sent from the clouds |
02-12-2015, 10:32 PM | #171 |
Pebble Pounder Join Date: Jan 2007 Location: H D
Just to confirm... The motor should be on the front passenger side??
02-12-2015, 10:39 PM | #172 |
Well, different places sit on the wrong side, or other side, so say it's at the front right would be better. First post picture shows that.
02-13-2015, 12:42 AM | #173 |
Rock Crawler Join Date: May 2012 Location: Upland
Thank you for the pictures
11-23-2017, 06:52 PM | #174 |
Pebble Pounder Join Date: Nov 2017 Location: Noblesville
so i get you unscrew the skidplate and rotate it 180 degrees. but how exactly do you flip the motor to still be on the front side?
11-27-2017, 03:07 PM | #175 |
Umm stupid photbucket...post 158 also shows. reversing output in gear box. Basically swapping so motor sets on opposite side This, stock motor on left To this, motor on right By separating transmission and flipping the input shaft so it sticks out other end. Keep the case in same orientation while working on it, moving parts left to right, right to left. pull spur gear pull trans from motor plate pop small cap off, set spacers to right (they also get flipped) slip bearing off Slowly separate case Pull complete shaft and gears assy with bearings Flip complete gear and shaft assy 180°, Insert into left half of trans case with shaft into left side close case All the parts that were on the left side (screws, cap & motor) now go to the right parts that were on right (bearing , spacers, spur gear) now go to left side reassemble The motor plate is also flipped-this is stock. Well, it doesn't flip but just moved to opposite side of trans Side that was against motor/trans now on opposite side - As you noted,, skid is rotated 'cause the holes for trans now on opposite side. No changes to motor required. Not a miraculous mod but it helps. Last edited by AnEv942; 11-27-2017 at 03:13 PM. |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-ax-10-scorpion/110323-mirror-imaged-transmission.html | ||||
Scx10 Tr - THE SCALE BUILDER'S GUILD - Presented by JOWETT'S KUSTOM RC | This thread | Refback | 10-04-2011 07:30 PM |
