Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: Ax 10 droop
Old 03-17-2008, 11:41 AM   #1
Illeagle's Avatar
Default Ax 10 droop
I am trying to setup some traxxas big bore shocks in a droop setup on my axial and had a couple questions.
On tcs they have medium and very soft internal springs, which ones are most guys using?
Also what weight oils are working the best?
Illeagle is offline   Reply With Quote
Old 03-17-2008, 12:52 PM   #2
YTC Team Driver
winkscrawler's Avatar
I run the medium springs with the stock axial shock oil with the edge chasis.
winkscrawler is online now   Reply With Quote
Old 03-17-2008, 01:44 PM   #3
I have been running full droop in the front and limited sprung in the rear. I have been using 1000 wt diff oil, it will carry the wheel over a hole if i need it to, but still allows for a ton of articulation. I think I am at about 80*. I know thats a little much for most people, but with the limited rear, it stays pretty stable.
ReklessOffRoad is offline   Reply With Quote
