03-28-2008, 08:23 AM | #1 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
| my new ax-10
finally got my crawler! its awesome ,love it. ax-10 scorpion rubicon body 87sp 14p stock 540 silver can tazer 15t esc thunder power lipo2c tcs internal springs soft and med ,35wt oil hot racing knuckles and c hot racing 3 link frnt,tcs boomerang 4 link rear rockcrushers,lizards,and mashers oh my! jr xrpro 3 fm synth 4 oz in frnt tires each,3 in back i know the tazer is a cheap sob but im really suprised how well it does. fwrd rev,and brake. the rev has delay before going back to fwd.not bad for 30 bucks. its just there till i get a mamba max and brshless motor. will post vid Last edited by ROLANDROCKSHOP; 03-28-2008 at 10:43 AM. |
03-28-2008, 08:37 AM | #2 |
03-28-2008, 08:52 AM | #3 |
Quarry Creeper Join Date: Aug 2005 Location: newport
Looking good. Though the torque lean would drive me crazy, I'd be doing something to stop that. Move the shocks out wider or go back to (soft?) springs outside the shocks. |
03-28-2008, 08:59 AM | #4 |
Pebble Pounder Join Date: Feb 2008 Location: Bala Cynwyd
looks good, i would also fix the lean. how do you keep the shaft's for popping off?
03-28-2008, 09:15 AM | #5 |
yes the LEAN is annoying but its tolerable it climbs so well tho. thanks for compliments. driveshaft rings to keep the drv shafts from popn off Last edited by ROLANDROCKSHOP; 03-28-2008 at 09:16 AM. Reason: im stupid |
03-28-2008, 10:21 AM | #6 |
Newbie Join Date: Mar 2008 Location: Phila
Looks good! I love the Rubicon body! Nice rock crushers too, I have a set but I put them on my New Brite FJ. Torque twist is bad in these things! I ordered new servo plates to mount the upper links to and I'm going to triangulate the lower links with a custom cutting board.
03-28-2008, 10:33 AM | #7 |
heres some more pics |
03-28-2008, 10:07 PM | #8 |
Rock Stacker Join Date: Feb 2008 Location: Where ever the Army puts me.
Truck looks great!! Do you find that the COG is kinda high with everything mounted on the top of the battery plate like that?
03-28-2008, 10:59 PM | #9 |
Pebble Pounder Join Date: Feb 2008 Location: Gonzales
Nice rig were putting that same body on my buddies ax-10 but we cut out the windows and cut the top off leaving the roll bar should finish the mount tomorrow. Also glad to see I'm not the only one with mad tq lean LOL |
03-28-2008, 11:11 PM | #10 |
yeah the gansta lean is baaad. it pretty much has to be on its side to roll and standing straight up to flip over im happy with it... for now. im going to my first comp 2mrw so well see how she does. got an xtra set of shocks setup to droop specs gonna swap em in an see how they do will post up my findings. |
03-28-2008, 11:27 PM | #11 |
Good luck at the comp cant wait till one comes closer to home so I can go give it a try.
04-21-2008, 11:22 AM | #12 |
well ive bought an edge chassis and made a low belly dragger. still got my stock chassis and now have 2. ta bash! edge chassis "hunglow" tcs edge chassis 3 oz zip tied to frnt axle hitec 144 oz tq servo holmes hobbies 55t hnd wound/12th lrp ai esc lipo 2s venom 1250 over 45mins! axial alum shock bodys w/ 35wt droop spec tcs internal springs soft frnt/med rear /w 1/4 cut soft spring on top tcs boomerang rear 4 link punisher rear shaft driveshft rings for frnt alum gears for tranny ht kncks and c ht 3 links and uppers ht bent arms ht skid rc4wd staight axle rc4wd bio hazard 2.2bdlks losi rock claws total weight of assm.wheel is 9oz total weight of veh. 6.4 lbs Last edited by ROLANDROCKSHOP; 04-21-2008 at 11:48 AM. |
04-21-2008, 11:47 AM | #13 |
heres my other ax 10 mamba max/5700 brushless mtr rc 4wd 2.1/4.1 reduction units running 2.1 now 4.1 is super low!! 2s lipo 1550 maxamps (you guys rock!) modified the radio plate to be as far forward as possible. 3oz zip tied to frnt axle alum gears in tranny w/ lucas gear oil say what you will but try it and youll never use anything else again. you dont hear any gear noise. punisher rear shaft frnt driveshaft rings tcs 4 link boomerang rc4wd straightaxle ad bent links ht alum skid plate ht alumknucks/c ht 3link/ uppers axial alum shocks w/ 35 wt tcs internal springs soft frnt/med rear normal setup. axial rockstarsw/rockcrushers 12 oz-junfac mudrocks w/rock lizards 15oz total weight is 6.8 lbs |
04-22-2008, 12:16 AM | #14 |
Quarry Creeper Join Date: Apr 2008 Location: Fondy, WI
ur edge looks great! would the maxamps lipo fit w/out any issues on your front servo or would it be too tight?
04-23-2008, 07:05 PM | #15 |
thanks. you mean on top yes,on the side no its too long. i have mine velcrod to frnt 3 link,keeps wght up fnt and down low. |
04-30-2008, 06:12 PM | #16 |
well havin no job sucks, but it gives me loads of free time, and i came up with this lil chassis tuber. made out of alum. drilld and tapd. uses stock ax-10 chassis took me @ 2hrs to make. simple design. if anyone would like to me make another ,hit my pm. |
