03-29-2008, 05:21 PM | #1 |
RCC Addict Join Date: Jul 2004 Location: The other Crawler State
| AX- 10 rock racer (tuber)
Well here it is, now there will be a lot of R&D to get this car dialed in. I took it for a spin, it seems fast enough, but I think it could be a bit faster. I am geared to 5:1 right now. I might just go down to 4.50:1 or something between the two. The suspension is nice for crawling, but seemed a little stiff for the higher speed dirt runs I made. That is going to be the hard part, getting the right balance between going fast and for crawling. It should be a fun experience to figure this thing out and get it dialed. Specs: Mr. Burpsalot tube chassis, modified by BMRC Ax-10 axles Ax-10 trans Axial aluminum bodied shocks RCP aluminum C's RCP aluminum knuckles RCP straight axle adapter with ss straight axles Novak RCE esc Koyoso Magnetic Mayhem 22t motor Hobbico CS-170 servo RC4WD Super Narrow (BL01N) wheels Axial sticky compound tires (subject to change) Northwest Traction Technologies 5.25" pinks On to the pics, Last edited by DUDE; 03-30-2008 at 10:48 AM. |
03-29-2008, 06:20 PM | #2 |
Rock Stacker Join Date: Sep 2004 Location: Orangevale
looks good
03-29-2008, 06:40 PM | #3 |
RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
Huh,.... I really like the looks of that chassis. Hmmmmm.
03-29-2008, 11:21 PM | #4 |
Quarry Creeper Join Date: Mar 2008 Location: Huntington Beach
very nice crawler. Wat shafts u running.
03-30-2008, 12:52 AM | #5 |
| Thanks, I just run the Pede shafts, they work. I also geared it up a bit more, I needed more speed. After running it some today I also changed out the tires to M3 Mashers and also had to pull out the pink memory foams. Those foams are too stiff at high speeds. I am going to try the Proline memory foams out I got with my new Hammer tires. This is more of a rock racer than crawler, but when I am done it will crawl and go fast. |
03-30-2008, 09:02 AM | #6 |
Quarry Creeper Join Date: Mar 2008 Location: Pittsburgh
Yeah, that is a nice looking ride. |
03-30-2008, 02:13 PM | #7 |
Quarry Creeper Join Date: Aug 2006 Location: Baumholder
Nice looking rig!
03-30-2008, 02:30 PM | #8 |
Rock Crawler Join Date: Mar 2008 Location: Plainfield
I like the shock mounts. Looks like a good ride! Lou |
03-30-2008, 09:30 PM | #9 |
Rock Stacker Join Date: Dec 2006 Location: in the workshop
are you running the lockers in the diffs for your racer ?
03-30-2008, 09:37 PM | #10 |
I like it Dude, I need to put a faster motor in my axial tuber so we can play. I'll need to soften up the suspension a little though. I'm thinking 35t on 3or4cell lipo should do the trick |
03-30-2008, 11:02 PM | #11 | |
I put a higher gear in this car and it hurt the torque needed for crawling, so I am going back to my original gear and changing out the motor. I am going to put in one of my old 27t racing motors, they are pretty fast and have some nice torque for what they are. I only have a 2c Lipo for this car. A 35t and a 3c will go pretty good for ya, get r done and lets run them at the comp coming up. I have to soften up the front suspension too, I am dumping out the 30wt and putting in some 10wt and run the same springs. | |
03-30-2008, 11:03 PM | #12 |
03-30-2008, 11:57 PM | #13 |
I'm going to be able to make the comp now for sure, it looks like at this point. I'll just need a motor for mine, all I have is one of Randy's High Velocity 10t motors that was in my XXXT....not going to work |
03-31-2008, 04:04 PM | #14 |
Quarry Creeper Join Date: Aug 2004
03-31-2008, 04:48 PM | #15 |
I haven't taken any pics of it yet Peter, I just put it together this weekend. Setup to use all the axial stock gear, except I put an R2 in it, but I may throw one of my axial trannies in it to lighten up the chassis a bit.
03-31-2008, 06:04 PM | #16 |
Quarry Creeper Join Date: Apr 2007 Location: .
Wow that is a nice tuber. I wanna get one
04-01-2008, 11:48 PM | #17 |
| Let me know if you have an axial trans you can part with on the cheap.
04-02-2008, 12:30 AM | #18 |
Sorry Peter, don't have any extras right now.:-(
04-02-2008, 01:42 AM | #19 |
04-02-2008, 08:24 PM | #20 |
