03-29-2008, 10:28 PM | #1 |
Newbie Join Date: Mar 2008 Location: Shepherdsville
| axle problems
when i put any load on my front my tires will not spin. the drive shaft spins. i was wondering if anyone had any ideas before i takethe axle apart
03-29-2008, 10:36 PM | #2 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
03-29-2008, 10:42 PM | #3 |
Quarry Creeper Join Date: May 2007 Location: Brenham, Tx
do you have pins in the outer axle shaft where the hex clamps on? sounds like you are missing a pin somewhere. either at the yoke or the end of the axleshafts
03-29-2008, 10:47 PM | #4 |
thanks. i will just take it apart tomorrow
03-29-2008, 11:32 PM | #5 |
Debunking old stereotypes Join Date: Feb 2006 Location: 1st and Amistad
Is the yolk tightened on the output shaft with 2 set screws? There's 2 holes tapped, use them both, (set screws are cheap). Sounds like your set screw is loose and the shaft is just spinning.
03-30-2008, 12:56 AM | #6 |
Quarry Creeper Join Date: Aug 2007 Location: United States
X2 on the set screws.
03-30-2008, 04:45 PM | #7 |
Rock Crawler Join Date: Nov 2007 Location: San Bernardino
Yeah I'll 3rd that |
03-30-2008, 05:21 PM | #8 |
i got it fixed. i use two set but the one that sets on the flatside of the shaft backed out.
