04-06-2008, 02:50 PM | #1 |
Pebble Pounder Join Date: Dec 2007 Location: York, PA
| Bent links in rear only?
Do you guys suggest running the bent links in the rear only? Someone suggested I do that but it was late at night and I put them in the front by accident. I am definitely concerned about handling the hills coming down, so I wanted to hear some of your thoughts on it. thanks |
04-06-2008, 03:14 PM | #2 |
Quarry Creeper Join Date: Feb 2008 Location: Plano. Il
I run bent link's front and rear. Some people only run them in the rear, as the rock or whatever you are crawling has already made it to the chassis once your front tire's are over it. I have not seen anyone put them up front only. It's all about trial and error. I've put many thing's togather only to find out I put it togather wrong. That's why you always put stuff togather first then read the instructions!
04-06-2008, 07:12 PM | #3 |
Rock Stacker Join Date: Feb 2007 Location: Ottawa, Canada
| rear
rear ( for me ) as per "stage two" and the advise above, once the front wheels have gone over it................................... ( instructions ??? ) |
04-06-2008, 07:22 PM | #4 |
Bent links,front and rear......... What if you need to back up something |
04-06-2008, 07:36 PM | #5 |
Pebble Pounder Join Date: Jan 2008 Location: Mission B.C. Canada
front and rear but if I only had one set I would put them on the back
04-06-2008, 08:33 PM | #6 |
Quarry Creeper Join Date: Sep 2005 Location: on the rocks
I used to run front and rear and now run rear only. My front links are dead flat though. Bent links in front on mine really dont help.
04-06-2008, 10:42 PM | #7 |
Rock Crawler Join Date: Apr 2007 Location: Denverish
Bent links will give you a little more clearance and can help on breakovers, but can flex when you're trying to push up a vertical face. Try both, see what you like.
04-06-2008, 10:45 PM | #8 |
04-07-2008, 07:40 AM | #9 |
Thanks for the replies guys. I will be moving the links tonight for sure
