04-17-2008, 02:08 PM | #1 |
Newbie Join Date: Apr 2008 Location: Denver
| Ax-10
I need help!!! So I finished my build and seems to work great!! the only thing is that my steering arm is not parallel to the main drag, what I do wrong? are my hubs on wrong? I have seen one or two wrong like mine and all the rest look to be fine. can you tell me whats wrong in the picture? thanks for the help!!!!! |
04-17-2008, 02:13 PM | #2 |
Newbie Join Date: Mar 2008 Location: Phila
Swap your knuckles/hubs.
04-17-2008, 02:17 PM | #3 |
Swap the knuckles/hubs huh okay now the dumb question move the front to the back? rotate? what as you can see im a noob all the way can you break it down for me? please |
04-17-2008, 02:35 PM | #4 |
Pebble Pounder Join Date: Jan 2008 Location: winston-salem
04-17-2008, 02:47 PM | #5 |
Hey I'll give that a try.so basically swap only the front because no steer in the rear, right? |
04-17-2008, 04:29 PM | #6 | |
Rock Stacker Join Date: Dec 2007 Location: New Brunswick, Canada
If you look at your c hubs, you will see that there is an angle to them, so you need to pay attention to what side they go on when you install them. | |
04-17-2008, 04:48 PM | #7 |
Hey Thanks Jason
04-17-2008, 08:01 PM | #8 |
Pebble Pounder Join Date: Jan 2008 Location: foothills of va.
i had the same problem after i built mine, all you have to do is rotate them 180 degrees, that will fix it, its not about swapping front to rear or left to right!, that didnt fix mine .
04-17-2008, 08:03 PM | #9 |
Rock Crawler Join Date: Nov 2007 Location: Dayton, Ohio
Mine is like that and its because my aluminum servo horn is shorter than the stock plastic servo horn axial gives with the kit.
04-17-2008, 09:10 PM | #10 |
| AX-10 hubs
Yup that worked! Thanks to All |
