05-28-2008, 10:57 AM | #41 |
Rock Crawler Join Date: Dec 2004 Location: www.ORCRC.com
yes
05-28-2008, 11:23 AM | #42 |
The thread tittle is very unassuming I tough another AX-10 build big deal and passed by it and then noticed the traffic and now I see why. Best AX-10 thread I've seen the tech was great no rookie here. By the way your rig looks terrific. |
05-28-2008, 12:22 PM | #43 |
RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
| X2 - it is always nice to see the 1:1 ingenuity brought to scale. Great ideas on the links.
05-29-2008, 09:06 AM | #44 |
hehe.... BTW - I'm now running (12) 2/3A cells (14.4V) with the integy 55T and a the 14pinoin /87 spur and its FUN! But my servo power SUCKS - so I've got a CC BEC ordered to fix that issue since the Mamba is kinda weak in that department. Last edited by 4RnrRick; 05-29-2008 at 09:09 AM. |
05-29-2008, 03:07 PM | #45 |
Rock Stacker Join Date: Mar 2008 Location: Temecula
I am currently running 4whl steering. How can i mount the rear uppers and still keep the rear steer? |
05-29-2008, 04:10 PM | #46 |
Under the front edge of the servo plate after you drill two new holes..... |
05-29-2008, 10:14 PM | #47 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
welcome back to the R/C world! I figured with the tuki going you would get the itch for this again. Looks great, just wish you were closer so we could wheel together. |
06-01-2008, 12:07 AM | #48 |
Rock Stacker Join Date: Feb 2008 Location: Shingle Springs, CA
As a relative n00b to rc crawing, I find this thread to be VERY informative. I believe it would be worthy of being stickied for other newcomers to the rc crawling world who want to get 'more' out of their stock scorps. Thanks to all who have contributed! -Moddy |
06-01-2008, 12:25 AM | #49 |
Pebble Pounder Join Date: Nov 2007 Location: Grand Junction, CO.
x2...............i totally agree....this is worth keepin stuck on top of the hill. please!
06-05-2008, 08:56 AM | #50 |
I honestly DON'T think it needs to be stickied...
06-05-2008, 11:14 AM | #51 |
the data presented??? the links?? the quality pictures and common sense approach with detailed instruction?.....hell it should be stickied just to show all the wannabe know it alls how to properly inform us ignorant folk if nothing else...lol no its a great thread. really smartened me up on the benifits and reason for a quality four link setup. glad i read this before i spent money on fancy alum. three link pieces.
06-05-2008, 08:06 PM | #52 |
OK, i drilled the holes in the chassis and the servo plate. I mounted the links underneath the plate due to servo being on top. You have to drill the holes pretty close to the edge of the plate so that the link will not hit the axle. I had to move the servo backwards on the back plate, so i moved the drag link to the otherside of the horn to get it to align backup again. I have not tested the rig yet on how it works. As you can see from my previous pic, should i flip the servo upside down and then switch the drag ling to the otherside so that the drag link is about 4 times longer than it is now? Or should i leave it? The servo could not be mounted with screws anymore so i used the black servo tape which seems to work. Last edited by tbizzle; 06-05-2008 at 08:07 PM. Reason: forgot about servo mounting |
06-05-2008, 08:12 PM | #53 |
With your setup, i was forced to flip the shocks due to binding at the top. The cap was hitting the chassis and binding, causing the cap to pop off.
07-03-2008, 03:02 PM | #54 |
Pebble Pounder Join Date: May 2008 Location: El Paso
any updates on the suspension set up? i dream of having almost zero TT!
09-25-2008, 03:55 PM | #55 | ||
Been busy with other things, the crawler got shoved off into a corner and the tires glued themselves to the dresser top. Finally dusted it off and got out and played with is some. Still working good. I also finally got the CC BEC programmed and added some aluminum knuckles. Oh and did I mention still no issues with the DIG or 12 sub C cells..... Nice burst speed! | ||
11-06-2008, 06:44 PM | #56 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
Nice Job on the dig man. |
11-06-2008, 09:41 PM | #57 |
I wanna be Dave Join Date: Sep 2008 Location: behind the wheel of a monster truck...
Awesome buildup man,lot's of good tech in here also!! |
11-07-2008, 12:47 PM | #58 |
Quarry Creeper Join Date: Oct 2008 Location: Southern Illinois
Loads of information here for brand new guys like myself!
11-08-2008, 10:20 PM | #59 |
RCC Addict Join Date: Jul 2008 Location: San Diego
thanks I took my plates off and drilled new holes-tied it out and it worked great-did it with my son today and check it on the rocks works great-thanks for the tips. Matt |
11-10-2008, 06:38 AM | #60 |
Newbie Join Date: Oct 2006 Location: Asia
thanks for the wonderful tips... I took half a day today modding my ax10 as stated in this thread... just some clarifications: I drilled 4 holes on the chassis for the front and rear upper links as instructed. 1. For the rear upper link, i use the lower link rod (98x6) and fixed them up on the 2 drilled holes on the rear servo plate. They are been connected at the top side. Distance btwn the two ends is abt 15mm. Is this right? 2. For the front upper link, the end pt at the chassis is blocked by my motor, i.e, no clearance to screw it there. So had to do it differently from the rear. I used back the original upper link rod and attached them to the original hole at the chassis. For the servo plate, I fabricated another servo plate that is slightly longer (abt 8mm longer), so that i could attached the rod without being obstructed by the servo. They are connected at the top side too. 3. Flipped all my 4 shocks. 4. Now, with this setup, the rear upper link is nearly perpendicular to the floor, but the front upper link is angled quite a bit. And the crawler is slightly lower in the front. Is this normal? 5. I will try to take some pics tmr... pic says a thousand words... Last edited by dabiddo; 11-10-2008 at 06:50 AM. |
