Standard issue: Black/Green Bug Ax-10 Well after 2 years with no RC's, I decided to get back into the sport... So it seemed pretty obvious to buy a AX-10. Got it all together and even ran 2 battery packs through it. Drives pretty nice but there is still too much torque twist for me. http://i230.photobucket.com/albums/e...C/DSC02074.jpg http://i230.photobucket.com/albums/e...C/DSC02075.jpg http://i230.photobucket.com/albums/e...C/DSC02077.jpg http://i230.photobucket.com/albums/e...C/DSC02076.jpg Axial AX-10 Kit ST Racing Bent Lower Links, STA30445G (same as Axial's) (3) Super Soft Axial Springs (red) (1) Hard Axial Spring (blue) {Left Rear} Rubber Shocks dampers installed inside the shocks Rear steer lockouts infront of axle. Removed Axial battery tray Homemade Saddle Battery mounts. Spaced Y links (front and rear) 55T 'Integy' Lathe motor 87/16 gearing 8 cell, 1450 Mah 'Elite' CheapBatteryPacks.com Deans connectors CastleCreations Mamba Max Traxxas TQ3 trasmitter and reciever Hitech HS645-MG with Aluminum Arm Cut foams with 4.5 oz in each front tire HPI Baja Bug body 12 5/8" WB, 2 7/8" Belly http://i230.photobucket.com/albums/e...C/DSC02073.jpg http://i230.photobucket.com/albums/e...C/DSC02068.jpg http://i230.photobucket.com/albums/e...C/DSC02070.jpg http://i230.photobucket.com/albums/e...C/DSC02078.jpg http://i230.photobucket.com/albums/e...C/DSC02079.jpg |
:shock: Well holy shit buddy! Looky who's back! Nice! |
"thumbsup" - yeap its been a while, hasn't it.... |
Will it become a tukisuzuki? |
I was wondering if you would ever get back into the little toys."thumbsup" |
The torque twist was bugging me so I started really researching what others do to try to fix it without major mods... Found some interesting stuff to try but I decided to try to put the suspension into the 1:1 link spreadsheets I'm use-to using 1:1 rigs I've built to help me understand whats going on. This is what I found for the setup I was running which is very simliar to stock with the rubber bumpers mounting inside the shocks to lower the stance and lengthed y-links: http://i230.photobucket.com/albums/e...ick/RC/old.jpg As you can see the links are near parrallel and actually show the instant center behind the vehicle. Then after messing with the numbers my goal was to add more seperation at the rear axle and reduce it some on the frame. and in teh process I would lengthed the upper links and get rigd of the y-link. This is what I ended up with. http://i230.photobucket.com/albums/e...ick/RC/new.jpg I'd like to try lowering the AS another 15% or so. and I wish the roll axis was closer to zero, but this will have to do for now. Also in doing this I outboarded the shocks and moved the links to the inside of the frame plates. And I swapped out the left rear spring back to a super soft axial red and added one fat coil spacer. This is what it looks like now. http://i230.photobucket.com/albums/e...C/DSC02084.jpg http://i230.photobucket.com/albums/e...C/DSC02085.jpg And here is a little tire test I did on my 39.5 Irok to simulate a steep climb. There is NO way I could have done that before! It would have totally torque twisted right off it. Click for short video http://i230.photobucket.com/albums/e...ax-10_IROK.jpg Then I took it out for some real testing. Click for short video http://i230.photobucket.com/albums/e...itled_0001.jpg Its defintely an improvement over what I had! Now my next big issue is probably tires and foams... I think I cut my foams up too much and it feels a little nose heavy so I might remove some weight out of the front tires. I'm also trying to decided if I want DIG or Rear Steer.... |
I took it to a ORCRC comp this weekend and got 11th out of 47.... Not bad for a basically stock Axial, no front dig and very little practice. http://i230.photobucket.com/albums/e...pApril2007.jpg |
re Very good!!! Could you please, take some pics from chassis frame without body in order to see where are new upper links holes are located?? THANK YOU"thumbsup" |
Thanks for sharing. Did you keep all link locations and setups stock in the front? |
Here is the current link configuration pics.... http://i230.photobucket.com/albums/e...C/DSC02103.jpg http://i230.photobucket.com/albums/e...C/DSC02104.jpg http://i230.photobucket.com/albums/e...C/DSC02084.jpg Stock rear lowers moved to the rear uppers with two new holes drill in the chassis and two holes drilled into the rear servo mount to convert it to a 4-link. as you can see this gives more seperation at the axle and less seperation at the chassis so the convergence point (instant center) is now really close to 100% AntiSquat for a nice neutral stance. |
Welcome back Rick!! "thumbsup" Glad to see you bring some nice tech with you too. |
Welcome back "thumbsup" You must be visiting over here while pirate is down :lol: |
Great job, very informative"thumbsup" |
talk about long time no see! I don't even know if you remember me but I remember you for "the wife". I remember that comp on elk rock. I think you were like the first to try 9.6v on a 2.2? I remember in the build up to that comp you were flaunting that vid of it doing back flips in the lawn hahaha. oh good times. by the way, awesome work with the stock ax setup "thumbsup" where do you get that suspension program? I know I have seen it before EDIT: I was looking through your old builds and they sure brought back the memories from the good 'ol days! :) |
i like the bug body alot on your rig |
re Thanks for sharing and pics!! "thumbsup""thumbsup" |
do you have a link to pictures of your 1:1 rig? |
http://www.pirate4x4.com/forum/showt...hreadid=204893 Link to the 3-link + Panhard Bar calculator. http://mysite.verizon.net/triaged/fi...kV1.0bBETA.zip Link to the 4-link calculator. http://mysite.verizon.net/triaged/fi...arLinkV3.0.zip You have to tweak the axis on the graph to RC scale. |
http://board.marlincrawler.com/index.php?topic=37942.0 Suzuki Samurai Soft Top Tub Toyota Taco 2.7L 3RZ motor (150 hp) R150F Toyota V6 tranny Dual 23 spline Transfer cases (2.28 X 4.70) 3-link + panhard front Double triangulated 4-link rear 2" remote reservior coilovers Toyota 8" axles (chromo axles, Detroits, 5.29 gears) 39.5" Irok's on 15x10 rims 108" WB with ~20" belly (at ride hieght) http://i230.photobucket.com/albums/e...i/DSC01929.jpg (still under construction) |
I bet my '90 accord could crawl better than that thing! haha jk it looks really great. Is that your old 4runner in there or a completely new rig? EDIT: one more thing: you mentioned how you still think 8 cells is too slow. Alot of people swear by the holmes hobbies' cobalt puller for low speed control and good wheel speed. also you can throw on an extra volt and a half with a lipo 3s... but you probably already know all this |
