04-27-2008, 04:38 PM | #1 |
Newbie Join Date: Jan 2008 Location: Greeneville/Cookeville
| Traxxas dimensions what are the dimensions of the u-joints and shaft ends for the pede or tmaxx? I would like to adapt to stock axial metal u-joint to traxxas shafts. Is it possible to fill and drill pede shafts? |
04-27-2008, 04:53 PM | #2 |
Rock Crawler Join Date: Sep 2004 Location: eureka
pede shafts will fit right on the axial yokes, the problem is that the axial yoke's ujoint pins are not very long.which is one of the main causes for the shafts poping out in the first place. i have tried to use jato drive-lines but couldn't get the yokes to not slip on the tranny and axle output shafts(cause the jato yokes are plastic so the set screw wouldnt get tight enough.) your 3 options are 1.traxxas metal yokes + pede shafts (easiest, might have to make the shafts longer by cutting them and gluing back together so you'll need 4 shafts 2. axial yokes + maxx yokes + maxx yokes(hardest cause of the modding and fitment around the spur but strongest) 3.traxxas metal yokes + jato shafts (easy and little stronger than pede shafts., also have to lengthen) there are some more options but these are the most common. i wish someone just made a premade tough shaft for the axial lol. |
04-27-2008, 04:57 PM | #3 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
04-27-2008, 09:49 PM | #4 | |
Rock Crawler Join Date: Sep 2007 Location: Denmark
found this on Clodzone Quote:
04-27-2008, 11:42 PM | #5 |
Quarry Creeper Join Date: Apr 2008 Location: Fondy, WI
now thats what i'm talkin bout! thank you mip!
