05-06-2008, 12:04 PM | #1 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
| ax10 metal trans gears................
would it be worth replacing the plastic stock tranny gears with metal....what would be a good set to get......................bob .... |
05-06-2008, 12:16 PM | #2 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
I've only seen a couple blown up plastic gears, I guess metal would be better for the full bullet proof trany. Here are aluminum ones. http://www.jpcustomrcs.atomicshops.c...30/5831979.htm Last edited by LIKES2CRAWL; 05-06-2008 at 12:19 PM. |
05-06-2008, 01:09 PM | #3 |
id be more to say wait until you need to replace your stock ones. I haven't seen much crawling compared to the vets around here. From my experience of the original tranny Axial copied the only gear failure I ever saw was poor owner maintenance. Keep it clean, the bearings lubed and she should last for a long time. Spend the money else where on things you need now. |
05-06-2008, 02:18 PM | #4 |
Pebble Pounder Join Date: Jan 2008 Location: Mission B.C. Canada
I would say the output shafts need upgrade more than gears. Im running the hot racing gears and GH racing alum case and VF outputs on the way. So far its been bullet proof. Metal gears are not really needed, but if you do you'll prob never have to worry about em again.
05-06-2008, 02:23 PM | #5 |
Quarry Creeper Join Date: Nov 2007 Location: in the shop, of corse!
i have 1 ax with the hot racing alum gears and case..home built outputs bulletproof!..and still i run a clutch disc..if something isgoing to break its not my trans or axle....gotta finish to win!! |
05-06-2008, 02:55 PM | #6 |
RCC Addict Join Date: Jun 2007 Location: San Antonio, Tx
im still running the stock gears , i have a 55t brushed intagy on 8.4 volts my whole drive line from the alxles to tranny is stock but pede shafts get poped off sometimes, like someone elts said spend your money eltswhere till you need to upgrade your gears
05-06-2008, 03:55 PM | #7 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
what motors are you running?
05-06-2008, 08:33 PM | #8 |
