Thread: Strongest motor plate
Old 05-25-2008, 06:42 AM   #1
Default Strongest motor plate
Anyone know who makes the thickest, strongest motor plate for the Scorpion? Some brand sites state the thickness and material, others don't. Badly need less flex and more material for all the mounting screws to bite into than what the stock motor plate provides! Thanks very much for any light you can shed on this!!!
BeeRC is offline   Reply With Quote
Old 05-25-2008, 06:50 AM   #2
VF (Visionary Fabrication) makes a motor thats about an 1/8 thick, pretty stout. TCS carries them in the vendors section.
JUSTGOINGSLOW is offline   Reply With Quote
Old 05-25-2008, 03:08 PM   #3
Thanks. Any other ideas on this? Is the VS plate considered the strongest & thickest one presently available?
Old 05-25-2008, 04:22 PM   #4
Location: Taylors Falls just hanging with the MNRCRC crew.
Yup bullet proof and the motor adjustably is awesome.
Stormin2u is offline   Reply With Quote
Old 05-25-2008, 04:58 PM   #5
If you want to be different, Go to your favorate wal-mart or k-mart and buy a cutting board(many colors to choose from) that measures around 1/4 inch thick. Trace the stock chassis plate to the board. This Idea is really strong. I seen it in action already both in competetion and bashing.
Da Hermit is offline   Reply With Quote
Old 05-25-2008, 05:03 PM   #6
Natedog's Avatar
Originally Posted by Da Hermit View Post
If you wasnt to be different, Go to your favorate wal-mart or k-mart and buy a cutting board(many colors to choose from) that measures around 1/4 inch thick. Trace the stock chassis plate to the board. This Idea is really strong. I seen it in action already both in competetion and bashing.
He was asking about the motor mount plate, not the chassis plates.
Good to hear cause the stocker flexes around like a ballerina in tights with an audience....LOL> Makes it hard to keep a good motor piniion mesh.
Old 05-25-2008, 05:11 PM   #7
Gotta say the VF motorplate is pretty damn strong! Also is allows you the option of using not only 540 size motors but also smaller outrunners...thats a bonus ;)
genki is offline   Reply With Quote
Old 05-25-2008, 05:15 PM   #8
Dammit, I knew something was not right.
Old 05-25-2008, 06:54 PM   #9
Another option is to run the Hot Racing chassis plate with their motor mount. It has an additional screw that comes up through the bottom chassis plate and threads into the motor plate to eliminate flex.
I have been running this combo in my scorpion with a goat brushless and it works much better than the stock setup.
http://www.hot-racing.com/?partnumber=SCP13301&c=420
http://www.hot-racing.com/?partnumber=SCP1801&c=420
MrBadExample is offline   Reply With Quote
Old 05-25-2008, 07:54 PM   #10
would one made out of 1/8" steel make the COG lower with the extra weight it would have made of steel....just a thought, cause i have some 1/8" steel hanging around................bob
bob1961 is offline   Reply With Quote
Old 05-25-2008, 08:02 PM   #11
So far the choices include the thick, strong and versatile VF silver aluminum motor plate at $29.99 and the thinner anodized & finned aluminum Hot Racing motor plate which has an extra screw hole so it can also be attached it to the skid plate for less flex for about $13.99. Are there other strong & thick motor plates out there to be chosen from?
Old 05-25-2008, 08:20 PM   #12
GET THE VF PLATE
sorry for the large type but some people just like to ask the same question over and over. The very first response (and the 7 or so after) answered your question with undeniable accuracy... yet your search continues?
Overcomplication runs rampant in this section sometimes.
p!nK
mrpink is offline   Reply With Quote
Old 05-25-2008, 10:17 PM   #13
Don't want to hijack this thread or anything, just wondering, since it appears no one makes a steel plate, is the vf plate made of stiffer aluminum? I've noticed that after awhile the motor screws start digging into the soft aluminum & then it's hard to get a nice gearmesh
tim the toolman is offline   Reply With Quote
Old 05-25-2008, 10:22 PM   #14
i have noticed alot of guys dont place a washer under the motor screw. thats the wrong thing todo. a washer spreads the laod out and keeps from digging into the aluminum. GET THE VF MOTOR PLATE!
btw USE WASHERS WITH YOUR MOTOR SCREWS!
dragonracing is offline   Reply With Quote
Old 05-25-2008, 11:08 PM   #15
Natedog's Avatar
Originally Posted by dragonracing View Post
...a washer spreads the laod out and keeps from digging into the aluminum. GET THE VF MOTOR PLATE!
X2. You could also cut out your own motor mount plate from some thicker higher grade aluminum and then drill and tap the mounting holes that hold it to the tranny.
Some nice motor mount screws with washers.
http://www.lunsfordracing.com/mm5/me...Category_Code=
Steel would be way too heavy and still too high up in the chassis for a motor plate.
Old 11-05-2008, 09:13 PM   #16
That motor plate loos so much better than a zip tie around the chassis LOL. I am going to order one in the morning
mastangs64501 is offline   Reply With Quote
Old 11-06-2008, 11:55 AM   #17
TEAM RCC
bcrofts's Avatar
get The Vf Plate
bcrofts is offline   Reply With Quote
Old 11-06-2008, 12:02 PM   #18
Hey gays, I need a stronger motor plate for my ax10. Which one should I get?
helhedded is offline   Reply With Quote
Old 11-06-2008, 12:07 PM   #19
ghetto fabulous newbie
I would get any 1/8" motor plate. VF or the EEM one. I am using one that is VERY similar(my own laser cut version) to the EEM's motor plate one and have had NO FLEXING what so ever.
http://www.eastendmachining.com/hedumoplfora.html
yotachump is offline   Reply With Quote
Old 11-06-2008, 12:13 PM   #20
